node-red-node-mysql-test 1.0.0
A Node-RED node to read and write to a MySQL database
npm install node-red-node-mysql-test
node-red-node-mysql
A Node-RED node to read and write to a MySQL database.
Either use the Node-RED Menu - Manage Palette - Install, or run the following command in your Node-RED user directory - typically ~/.node-red
npm i node-red-node-mysql
Allows basic access to a MySQL database.
This node uses the query operation against the configured database. This does allow both INSERTS and DELETES.
By its very nature it allows SQL injection... so be careful out there...
The msg.topic must hold the query for the database, and the result is returned in msg.payload.
Typically the returned payload will be an array of the result rows.
If nothing is found for the key then null is returned.
The reconnect retry timeout in milliseconds can be changed by adding a line to settings.js
mysqlReconnectTime: 30000,
The timezone can be set like GMT, EST5EDT, UTC, etc.
The charset defaults to the "old" Mysql 3 byte UTF. If you need support for emojis etc then use UTF8MB4.
Preparing Queries
msg.payload=[24, 'example-user'];
msg.topic="INSERT INTO users (`userid`, `username`) VALUES (?, ?);"
with named parameters:
msg.payload={}
msg.payload.userToChange=42;
msg.payload.newUsername="example-user";
msg.topic="INSERT INTO users (`userid`, `username`) VALUES (:userToChange, :newUsername) ON DUPLICATE KEY UPDATE `username`=:newUsername;"
Documentation
Documentation of the used Node.js package
Version: 1.0.0
Updated 4 years, 7 months ago
14 in the last week
  • MySQLdatabase
  • mysql
  • mysql
