node-red-node-mui-etable 0.1.5
A Node-RED UI Node to create an editable table based on the Tabulator libraries.
npm install node-red-node-mui-etable
mDashboard (mui) version
This node is based on the capabilities of the Tabulator library and allows the user to define complex - editable tables and constructs.
Credit must go to Kazuhito Yokoi for his inspiration. node-red-node-ui-table
This node differs from node-red-node-ui-table due to it being more native to the Tabulator libraries, it allows very complex editable tables to be built, although this means that the configuration of the node now must follow the http://tabulator.info json format.
Eg
Options can be
{ "layout": "fitColumns", "movableColumns": true, "addRowPos": "top", "pagination": "local", "paginationSize": 15 }
Columns can be
[ {title:"Name", field:"name", editor:"input"}, {title:"Task Progress", field:"progress", align:"left", formatter:"progress", editor:true}, {title:"Gender", field:"gender", width:95, editor:"select", editorParams:{values:["male", "female"]}}, {title:"Rating", field:"rating", formatter:"star", align:"center", width:100, editor:true}, {title:"Color", field:"col", width:130, editor:"input"}, {title:"Date Of Birth", field:"dob", width:130, sorter:"date", align:"center"}, {title:"Driver", field:"car", width:90, align:"center", formatter:"tickCross", sorter:"boolean", editor:true} ]
Version: 0.1.5
Updated 7 years ago
40 in the last week
  • mui_etable
