node-red-node-markdown 0.6.3
A Node-RED node to convert a markdown string to html.
npm install node-red-node-markdown
Either use the Node-RED Menu - Manage Palette - Install, or run the following command in your Node-RED user directory - typically ~/.node-red
If the input is a string it tries to convert it into an html string.
Uses the markdown-it library - You can see a demo here.
It is configured with html, linkify and typographer options turned on.
Version: 0.6.3
Updated 4 months, 2 weeks ago
42 in the last week
  • markdown
  • markdown
