node-red-node-jy-archer 0.0.2
jy-archer allows you to exchange data with Archer Html Page
npm install node-red-node-jy-archer
Run the following command for global install
npm install -g node-red-node-jy-archer
How to use
  1. Place the node within your flow
  2. Configure the IP of your Luxtronik, the port and your webinterface password
  3. Trigger the node via the input, it doesn't matter what type the input is
  4. The node querys the heat pump for the data, parses the response and outputs the parsed result
Authors
The module was developed by jinyistudio.
Version: 0.0.2
Updated 5 years ago
9 in the last week
  • jy-archer out
  • jy-archer in
  • jy-archer eval
  • jy-archer run
  • jy-archer out
  • jy-archer in
  • jy-archer eval
  • jy-archer run
  • jy-archer out
  • jy-archer in
  • jy-archer eval
  • jy-archer run
  • jy-archer out
  • jy-archer in
  • jy-archer eval
  • jy-archer run
  • Pi
  • archer
  • svg
  • jinyistudio
  • dashboard
