node-red-node-cbor 1.0.2
A Node-RED node to pack and unpack objects to cbor format
npm install node-red-node-cbor
node-red-node-cbor
A Node-RED node to pack and unpack objects to cbor format buffers.
Changes
Version 1.0.0 - move to cbor-x library (more supported and faster). Usage
Uses the cbor-x npm to pack and unpack msg.payload objects to cbor format buffers.
Note: this node does not currently encode raw buffer types. It will automatically try to decode any buffer received, and may not cause an error.
If the input is NOT a buffer it converts it into a msgpack buffer.
If the input is a msgpack buffer it converts it back to the original type.
Version: 1.0.2
Updated 1 year, 4 months ago
4 in the last week
  • cbor
  • cbor
