node-red-neo4j 1.1.0
A Node-RED node for interacting with Neo4j
npm install node-red-neo4j
Node-RED Neo4j Project
This project includes a configuration node and a query node for interacting with a Neo4j database. The Neo4j Query Node is designed with developer friendliness in mind, allowing users to execute multiple queries in a single run without the need to build loops in Node-RED or manage complex flows.
Neo4j Config Node
Properties:
  • Name: (String, required) Name of the configuration.
  • URI: (String, required) Database URI (e.g., neo4j://localhost:7687).
  • Username: (String, required) Username for authentication.
  • Password: (String, required) Password for authentication.
  • Database Name: (String, optional) Default database name, defaults to default.
Neo4j Query Node
Properties:
  • Cypher Query: (String, required) The actual query to execute.
  • Parameters: (Object, optional) Accepts key-value pairs for parameterized queries.
Input Examples:
The Neo4j query node now supports executing multiple Cypher queries in a single input. The input payload can be either:
  • A single object containing the query and its parameters:
        "query": "MATCH (n) RETURN n",
        "params": {}
  • An array of query objects:
        { "query": "MATCH (n) RETURN n", "params": {} },
        { "query": "MATCH (m:Label) WHERE m.property = $value RETURN m", "params": { "value": "someValue" } }
In both cases, the results will be processed and returned as an array of objects.
Using npm
You can install the package via npm using the following command:
After installing, restart your Node-RED instance to see the nodes in your palette.
Using Node-RED Palette Manager
  1. Open your Node-RED editor in a web browser.
  2. Click on the menu (the three horizontal lines in the top right corner) and select Manage palette.
  3. Go to the Install tab.
  4. In the search box, type node-red-neo4j and hit enter.
  5. Click the install button next to the package when it appears in the search results.
  6. Once installed, restart your Node-RED instance to see the nodes in your palette.
Changes in v0.2.1
Enhanced Transaction Management
  • Implemented transaction management in the Neo4j query node to handle sessions properly and maintain data integrity during query execution.
Version: 1.1.0
Updated 2 years, 1 month ago
2 in the last week
  • neo4j config
  • neo4j query
  • neo4j
