node-red-nagios-nsca-send 0.0.13
A Node-RED node to forward to Nagios using NSCA send
npm install node-red-nagios-nsca-send
A Node-RED node to send data to Nagios via its NSCA service.
Nagios is a monitoring system. It has the NSCA service that allows data from so called passive checks to be transmitted.
This node uses allows you to send data to that NSCA service using the send_nsca command on your system.
The node is currently under devolpment. It does all I expect it to do. Further development might take place any time or never.
It is designed to run under Linux. Tested on Ubuntu 16.04 Server.
Further instructions will follow as this project progresses. Please be patient. Thanks.
August 15th 2019
Version: 0.0.13
37 in the last week
  • nagios-nsca-send
  • nagios
  • nsca
