node-red-mocknode 0.1.6
A Node-RED node to gen Data by mockjs
npm install node-red-mocknode
node-red-mocknode
A Node-RED node to create a mockdata for test-cases.
Example
The example flow below produces a JSON string which is then converted into an object, for example:
{ "array|3": [ "Hello", "Mock.js", "!" ]}
Version: 0.1.6
Updated 4 years, 1 month ago
Rating: 5.0 3
  • mocknode
  • data-generator
  • mockjs
  • json
  • mock
