node-red-lvsy 0.0.1
This repositry create a custom Node-Red node for configing TDEngine server connection and execute SQL from preview node msg.payload ## Design Use Taos data restful API to commit SQL, API call like
npm install node-red-lvsy
Design
curl -H 'Authorization: Basic <TOKEN>' -d '<SQL>' <ip>:<PORT>/rest/sql/[db_name]
Input options:
  • DB Server: Setup server connection or select a exist server
  • DB Name: Database to execute SQL
Use axios to call http request
  1. Start Node-Red
  2. Install TDEngine node
  3. Add "taos query" node to workspace from palette
  4. Setup a TDEngine server and database name
  5. Add function or other node to create SQL, put SQL into msg.payload
  6. Link to "taos query" node
Demo
  1. Start Node-Red by docker
docker run -it -p 1880:1880 -v node_red_data:/data --name mynodered nodered/node-red
  1. Import sample flow "demo/flow.json"
  1. Install TDEngine node by name "node-red-contrib-tdengine", current version is 0.0.2
  1. Modify your TDEngine server config
  1. Edit test SQL
  1. Start flow by click Inject node
Version: 0.0.1
Updated 2 years ago
  • taos-config
  • taos-query
  • tdengine
