node-red-loxone-icons 1.0.1
Custom Loxone-style icons for Node-RED subflows and nodes
npm install node-red-loxone-icons
Custom Loxone-style icons for Node-RED subflows and nodes.
npm version
Overview
This package provides a collection of SVG icons designed for Loxone-style home automation blocks in Node-RED. The icons are automatically available to all nodes and subflows after installation.
Via Node-RED Palette Manager (Recommended)
  1. Open Node-RED editor
  2. Click Menu (☰) → Manage palette
  3. Go to Install tab
  4. Search for: node-red-loxone-icons
  5. Click Install
Via npm
For Home Assistant Node-RED add-on:
cd /config
Restart Node-RED after installation.
Available Icons
Icon Filename Use Case
🎚️ mixer.svg Heating mixer (Mvco) / Valve controller
❄️🔥 hvac.svg HVAC / Climate control
📈 heating-curve.svg Heating curve calculator
🚰 valve.svg Valve control
🔌 usb.svg USB / Connection
In Subflow JSON
When creating or editing a subflow, use the icon path format:
  "type": "subflow",
  "name": "My Heating Mixer",
  "icon": "node-red-loxone-icons/mixer.svg",
  "color": "#E2D96E"
In Custom Nodes
RED.nodes.registerType('my-custom-node', {
    category: 'home automation',
    icon: 'node-red-loxone-icons/hvac.svg',
    // ... other properties
Examples
Heating Mixer (Mvco):
HVAC Controller:
"icon": "node-red-loxone-icons/hvac.svg"
Heating Curve:
"icon": "node-red-loxone-icons/heating-curve.svg"
Icon Format
  • Format: SVG (Scalable Vector Graphics)
  • Optimized for Node-RED's icon system
  • Consistent sizing and styling
  • Compatible with all Node-RED themes
Compatibility
  • Node-RED version: 3.0.0 or higher
  • Works in:
    • Standalone Node-RED installations
    • Node-RED Docker containers
    • Home Assistant Node-RED add-on
    • All operating systems (Windows, Linux, macOS)
Troubleshooting
Icons not appearing after installation
  1. Restart Node-RED - Icons are loaded during startup
  2. Clear browser cache - Press Ctrl+Shift+R (or Cmd+Shift+R on Mac)
  3. Delete old subflow - Remove old version from palette before importing new one
  4. Check package installation:
    npm list node-red-loxone-icons
Wrong icon path
Make sure to use the full path including package name:
  • ✅ Correct: node-red-loxone-icons/mixer.svg
  • ❌ Wrong: mixer.svg
  • ❌ Wrong: icons/mixer.svg
Contributing
Want to add more icons or improve existing ones?
  1. Fork the repository
  2. Add your SVG icons to the icons/ folder
  3. Update README with icon descriptions
  4. Submit a pull request
Icon Guidelines:
  • SVG format only
  • Keep file size under 5KB
  • Use simple, clear designs
  • Test in Node-RED before submitting
MIT License - See LICENSE file for details
Author
Created for the Node-RED and Loxone communities.
Links
Changelog
1.0.0 (2026-02-13)
  • Initial release
  • 5 custom icons: mixer, hvac, heating-curve, valve, usb
  • Full Node-RED compatibility
  • Support for Home Assistant Node-RED add-on
Version: 1.0.1
Updated 9 months, 1 week ago
  • loxone-icons-dummy
  • loxone
  • icons
  • home-automation
  • smart-home
