node-red-http-event-collector 0.0.2
The purpose of this project is to allow node-red to publish a node-red payload to Splunk's HTTP Event Collector.
npm install node-red-http-event-collector
Synopsis
This node pushes data to Splunk's HTTP event collector. Configure a new data source within Splunk's interface under settings> data inputs> Http Event Collector. Either create a new source or use an existing. Once finished setting up the source, you will receive a Token. This token will be added to the node settings within the node-red UI. The next step in setting up your HTTP Event Collector, is to make sure that the Global setting are correct. In the top right hand corner of the Splunk UI, while in the Http Event Collector Configurator, there is a Global settings button. Ensure "All Tokens" is enabled and that the "Enable SSL" button is checked. Also take note of the HTTP Port Number, This will be used later. Now go back to the Node-Red UI and add the "http event collector" node and double click to open settings. Paste the Token from Splunk into the Token's field and enter in the URI, ensuring to include "https://" Now add your ip or host name. Finally add the port, which will typically be "8088", but can be manually changed by noting HTTP Port Number in the Global Settings of the Http Event collector configuration page.
Motivation
Wanted to make an easy avenue to publish data into Splunk through Node-Red.
npm install -g http-event-collector
From github: Navigate to the your home directory on linux is is ~/.node-red/node-modules
git clone https://github.com/gdziuba/http-event-collector.git
cd http-event-collector
npm install
Setup
Navigate to your node-red instance and add the http-event-collector node. Double click to edit the node parameters.
Example configuration
Version: 0.0.2
Updated 1 month ago
0 in the last day
39 in the last month
  • http-event-collector
  • splunk
  • HTTP Event Collector
  • HEC
  • Machine
  • Machine Data
  • Analytics
  • Machine Learning
  • gdziuba
