node-red-data-logger 0.1.0
Logs data stored in JSON object into a CSV file with columns extracted from JSON object.
npm install node-red-data-logger
node-red-contrib-csv-logger
A Node-RED Node that logs data stored in JSON object into a CSV file with columns extracted from JSON object.
This was first created by senselik, however I (Kepler7894i) needed to make some changes to the very useful npm package they provided (node-red-data-logger) - and have since decided to re-release it. Many thanks to the original creator.
  • Data to be logged should be passed in msg.payload as a JSON object. The header row will be populated with the property names of the JSON object on log file creation.
  • The Columns property in node properties can be used as a filter if filled with JSON object's property names as comma separated string. If left empty, all properties of JSON object in msg.payload will be logged to file.
  • msg.path should be passed in for setting the location where the file will be logged into.
  • msg.fileName should be passed in to set the file name of the log file.
  • msg.slashType can be passed to set whether files will be created in directories using forward("/") or back("") slashes, enabling override in case of OS misdetection - no entry will leave to default
Version: 0.1.0
Updated 1 year, 1 month ago
  • data-logger
  • data logger
  • csv logger
  • logger
