node-red-dashboard-2-vue-color-wheel 0.2.0
FlowFuse Dashboard 2 widget wrapping vue-color-wheel
npm install node-red-dashboard-2-vue-color-wheel
Node-RED Dashboard 2 - Vue Color Wheel Widget
A custom widget for FlowFuse Dashboard 2 that provides an intuitive RGBW color picker with power control and brightness adjustment.
License Node-RED
  • 🎨 Interactive Color Wheel - Aurora or Spectrum wheel with harmony color selection
  • 💡 Power Switch - Large, intuitive on/off toggle
  • 🔆 Brightness Control - Smooth dimmer slider (0-100%)
  • 🌡️ Warm White Channel - Dedicated warmwhite slider for RGBW lighting
  • 📱 Responsive Design - Adapts to container size (minimum 200px)
  • 🔄 State Persistence - Maintains state across page reloads
  • 🎯 Multiple Instances - Support for multiple widgets on the same page
Via the Node-RED palette manager or npm (recommended)
Search for node-red-dashboard-2-vue-color-wheel in Manage palette → Install, or run:
Restart Node-RED afterwards.
Install from GitHub
npm install github:Acrylangel/node-red-dashboard-2-vue-color-wheel
Restart Node-RED afterwards. The prebuilt bundle in resources/ is part of the repository, so no build step is needed.
Manual installation from a local checkout
git clone https://github.com/Acrylangel/node-red-dashboard-2-vue-color-wheel.git
npm install /path/to/node-red-dashboard-2-vue-color-wheel
Important: Always install through npm install inside your Node-RED user directory (~/.node-red). Dashboard 2 only loads third-party widgets that are listed under dependencies in ~/.node-red/package.json. If you just copy the folder into ~/.node-red/node_modules (or into a nodes directory), the node shows up in the editor, but the widget stays invisible in the dashboard and the browser console reports No Vue component found for ui-vue-color-wheel - falling back to ui-template.
Basic Setup
  1. Add the color wheel node (palette category dashboard 2) to your flow
  2. Configure it to use a Dashboard 2 group
  3. Connect input/output nodes as needed
Input Message Format
Send messages to the widget to update its state:
// Set power, brightness, and color
msg.payload = {
    power: true,           // boolean - on/off state
    brightness: 75,        // number (0-100) - brightness percentage
    red: 255,              // number (0-255) - red
    green: 128,            // number (0-255) - green
    blue: 0,               // number (0-255) - blue
    white: 50              // number (0-255) - warm white
// Update only specific values
msg.payload = {
    power: false
// Change color only
msg.payload = {
    blue: 0
Output Message Format
The widget sends messages on user interaction:
Power Toggle Event
    payload: {
        power: true,        // boolean - new power state
        brightness: 75      // number (0-100) - current brightness
    topic: 'power-toggle'
Brightness Change Event
    payload: {
        power: true,        // boolean - current power state
        brightness: 50      // number (0-100) - new brightness
    topic: 'brightness-change'
Color Change Event
KNX DPT 251.600 ready
    payload: {
        white: 200,         // number (0-255) - warm white
        mR: 1,
        mG: 1,
        mB: 1,
        mW: 1
    topic: 'color-change'
Widget Behavior
Power Control
  • Click the large power button to toggle on/off
  • When OFF: Color selection is disabled (grayed out)
  • When ON: Full access to color and brightness controls
Brightness Slider
  • Range: 0-100%
  • Sliding to 0% automatically turns power OFF (without triggering power event)
  • Sliding above 0% automatically turns power ON
  • Turning power ON when brightness is 0% sets brightness to 100%
Color Selection
  • Click the Color button to access detailed controls
  • Choose colors using the interactive color wheel
  • Adjust warm white channel independently
  • Click Back to return to the main view
Responsive Sizing
  • Widget adapts to container width
  • Minimum diameter: 200px
  • Maximum: configured radius (default 160px)
  • Automatically recalculates on window resize
The widget accepts the following configuration options:
  • Group - Dashboard 2 group assignment
  • Size - Widget width/height within the group
  • Name - Display name for the widget
  • Allow Color Wheel - yes shows the color selection, no reduces the widget to power switch and brightness slider
  • Radius - Color wheel radius in pixels (default: 160)
  • Wheel Type - aurora or spectrum
  • Harmony - Color harmony mode: monochromatic, complementary, analogous, triad, split, compound, tetradic, square, doubleSplit
Technical Details
Dependencies
This widget integrates the excellent vue-color-wheel library by @xiaoluoboding.
Core Dependencies:
  • vue ^3.4.27
  • colord ^2.9.3
  • moveable ^0.53.0
  • gsap ^3.12.5
  • @vueuse/core ^10.9.0
Build
npm run build
Generates UMD bundle in resources/ui-vue-color-wheel.umd.js
Architecture
  • Frontend: Vue 3 (Options API) with TypeScript
  • Backend: Node-RED node (CommonJS)
  • Build Tool: Vite
  • State Management: Dashboard 2 Vuex store
Credits
Vue Color Wheel Library
This widget incorporates and extends the vue-color-wheel component.
Original Author: @xiaoluoboding
Repository: https://github.com/xiaoluoboding/vue-color-wheel
The original library has been integrated locally with modifications to support:
  • Multiple instances on the same page (unique IDs)
  • Dashboard 2 integration patterns
  • RGBW color model with warm white channel
  • Custom UI/UX enhancements
Special thanks to the original author for creating such an elegant color picker component!
MIT License
Copyright (c) 2024
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
Support
For issues, questions, or feature requests, please open an issue on the GitHub repository.
Changelog
Version 0.2.0
  • Node is now listed in the dashboard 2 palette category (was: dashboard)
  • Added the missing Wheel Type option (aurora / spectrum) to the node editor
  • Added the Size option (width/height within the group)
  • Widget labels are now English (ON/OFF, Brightness, Color, Back, Warm White)
  • README: installation from GitHub/local checkout and a note why copying the folder manually does not work
  • package.json: repository, license and author metadata for npm
Version 0.1.0
  • Initial release
  • Power switch with on/off control
  • Brightness dimmer (0-100%)
  • RGBW color wheel with warm white channel
  • Responsive design
  • State persistence
  • Multiple instance support
Version: 0.2.0
Updated 3 weeks, 5 days ago
  • ui-vue-color-wheel
  • dashboard
  • flowfuse
  • widget
  • vue
  • node-red-dashboard-2
  • color picker
  • rgbw
  • knx
