node-red-dashboard-2-robot-arm 0.2.0
Node-RED + FlowFuse Dashboard 2 robot arm: realistic UR5e URDF/STL viewer, teach pendant, optional ROS2 rosbridge. Palette: robot, controller, ui-robot-arm, ui-robot-controller.
npm install node-red-dashboard-2-robot-arm
A Node-RED robot-arm node for a UR5e: a 3D view of the real URDF meshes, a teach pendant, and optional ROS 2 joint feedback. On a Dashboard 2 page the arm and the pendant sit side by side. You can also drive the arm from Inject or Function nodes without a dashboard.
Palette name: node-red-dashboard-2-robot-arm. The dashboard-2 part is required so an existing Dashboard 2 install will show the arm and pendant on the page. Guide: https://github.com/t-teja/node-red-contrib-robot-arm#readme
Add it in Node-RED
  1. Open the editor menu → Manage palette → Install.
  2. Search for node-red-dashboard-2-robot-arm and install it.
  3. For the on-page 3D view and pendant, also install @flowfuse/node-red-dashboard (Dashboard 2) if it is not already there.
  4. Restart Node-RED if the new nodes do not appear. They show up under robotics, and the two dashboard widgets under dashboard.
The robot and controller nodes work without Dashboard 2. The ui-robot-arm and ui-robot-controller widgets need it.
The four nodes
Node What you use it for
robot The arm. Holds the UR5e model, accepts joint commands, and publishes the current joint state.
controller A teach pendant on its own page. Wire its output into robot.
ui-robot-arm Dashboard 2 widget. Shows the 3D arm for a robot node you pick.
ui-robot-controller Dashboard 2 widget. Pendant for that same robot node. No extra wire is required.
 Inject / Function / rosbridge          Dashboard 2 page
            │                           ┌─ ui-robot-arm ────────┐
            ▼                           │       3D view         │
     ┌──────────────┐                   ├─ ui-robot-controller ─┤
     │    robot     │◀── pendant ───────│    joint sliders      │
On robot, choose the model:
Preset What you get
ur5e UR5e arm, official-style meshes. This is the default.
ur5e-gripper The same arm plus a simple two-finger gripper on the tool.
Use it on a dashboard
This is the layout in example 05 Dashboard 2.
  1. Import that example (see Examples below).
  2. Deploy.
  3. Open the Dashboard page Robot Arm. With a normal Dashboard 2 install that is http://<your-node-red-host>:1880/dashboard/robot.
  4. The left panel is the 3D arm. The right panel is the pendant.
The base stays in the middle of the 3D panel, and the zoom fits the panel. You can orbit around the base. The pendant sliders, Home, and Freeze move that same arm.
If you already have a dashboard, you do not have to import the whole example. Add a robot node, then add ui-robot-arm and ui-robot-controller to a page and, in each widget, select that robot node.
Freeze is a soft stop in the UI. It is not a hardware emergency stop. See Safety.
Use it from a flow
Drop a robot node on a tab and deploy. Anything you send to its input becomes the next joint command, and the output is the joint state after that command.
The node status shows a 3D view path, /robot-arm/view/<robot-node-id>. Open that on the Node-RED host to see the arm without Dashboard 2.
A separate controller node is the same pendant on its own page. Wire controller → robot, deploy, and open the controller URL shown on that node (/robot-arm/controller/<id>). Example 02 is this wiring.
Examples
After the package is installed, the examples are in the editor:
Menu → Import → Examples → node-red-dashboard-2-robot-arm
Import one, then deploy.
Example What to do with it
01 Inject demo Three Inject nodes: Home, Reach, and Wave. Click one and the arm moves. A debug node shows the joint state coming out of robot.
02 Controller to robot Pendant wired into the arm. Open the controller URL on the controller node and move the sliders.
03 Rosbridge live robot with rosbridge turned on, subscribed to /joint_states. Use this when a ROS 2 robot or simulator is publishing joint states.
04 Controller and ROS 2 Pendant and rosbridge together. While the pendant is armed, its commands win for about 2 seconds over incoming /joint_states. Disarm the pendant to let ROS drive the view.
05 Dashboard 2 A Dashboard page named Robot Arm with the 3D view and the pendant bound to one robot node. Start here if you want the arm on a dashboard.
Messages
Send any of these on the robot input. The output is always the canonical object below.
Canonical command and state:
  "robot": "robot",
  "joints": {
    "shoulder_pan_joint": 0,
    "shoulder_lift_joint": -1.57,
    "elbow_joint": 1.57,
    "wrist_1_joint": -1.57,
    "wrist_2_joint": -1.57,
    "wrist_3_joint": 0
  "unit": "rad",
  "source": "pendant",
  "ts": 1710000000000
Also accepted: a ROS JointState style { "name": [...], "position": [...] }, a flat map of joint name to number, or an array of numbers in the joint order above.
Why slider limits are 6.28 and 3.14
The pendant uses radians. A full circle is 2 × π ≈ 6.2832 rad = 360°. Half a circle is π ≈ 3.1416 rad = 180°.
Joints Slider range Meaning
Base, Shoulder, Wrist 1, Wrist 2, Wrist 3 −6.2832 … 6.2832 One full turn either side of zero (±360°)
Elbow −3.1416 … 3.1416 Half a turn either side of zero (±180°)
These are the UR5e joint limits from the model, not an arbitrary slider size. Home on the pendant returns each joint to its home angle (straight-up style pose: shoulder −1.57 rad, elbow 1.57 rad, and so on). The number beside each slider is the current angle in radians.
ROS 2
Optional. On the robot PC or simulator:
ros2 launch rosbridge_server rosbridge_websocket_launch.xml
On the robot node, enable rosbridge and set:
  • URL: ws://<robot-pc>:9090
  • Subscribe topic: /joint_states (sensor_msgs/JointState)
  • Publish topic: optional. When set, commands leaving this node are published there.
This node talks to rosbridge over WebSocket. It does not speak DDS itself. Nothing moves unless something publishes /joint_states or you send a command from the pendant or a flow.
When the pendant is armed, its updates are preferred over rosbridge for about 2 seconds. After that, the latest message wins.
Safety
Not SIL-rated. This is a viewer and a soft teach pendant. Freeze only stops commands inside this UI. Do not use it as the emergency stop or safety controller for a real arm.
MIT © 2026 Teja.
The UR5e meshes are BSD-3-Clause, Copyright Universal Robots A/S, from UniversalRobots/Universal_Robots_ROS2_Description. See models/ur5e/LICENSE. The gripper in the ur5e-gripper preset is a simple box model, not a Robotiq CAD model.
Version: 0.2.0
Updated 18 hours ago
  • robot
  • controller
  • ui-robot-arm
  • ui-robot-controller
  • node-red-dashboard-2
  • robotics
  • urdf
  • ros2
  • three.js
  • robot-arm
  • ur5e
