node-red-cosmos-r2 2.1.0
A Node-RED custom node that connects to a Cosmos DB and performs create, update, read, delete, and upsert operations.
npm install node-red-cosmos-r2
node-red-cosmos-r2
Install the node-red-cosmos-r2 node from the command line:
Then, restart your Node-RED instance to load the new node.
  • Connect to Cosmos DB using URI, Key, Database ID, and Container ID
  • Perform create, read, update, delete, and upsert operations
  • Configure operations using input messages
Add the cosmos-r2 node to your Node-RED flow and configure it with the following properties:
  • Name: (Optional) A custom name for the node
  • URI: The Cosmos DB endpoint URI
  • Key: The Cosmos DB key
  • Database ID: The Cosmos DB database ID
  • Container ID: The Cosmos DB container ID
The input message must contain the following properties:
  • operation: The type of operation to perform, either "create", "read", "update", "delete", or "upsert"
  • item: (Optional) The item to create, update, delete, or upsert. Required for "create", "update", "delete", and "upsert" operations
  • query: (Optional) A query to filter items for "read" operation. If not provided, all items will be retrieved
The output message will contain the following property:
  • payload: The result of the operation, such as created, read, updated, deleted, or upserted items
Examples
Create an item:
  "operation": "create",
  "item": {
    "id": "1",
    "name": "Example Item"
Read items:
  "operation": "read",
  "query": "SELECT * FROM c WHERE c.name = 'Example Item'"
Update an item:
  "operation": "update",
  "item": {
    "id": "1",
    "name": "Updated Item"
Delete an item:
  "operation": "delete",
  "item": {
    "id": "1"
Upsert an item:
  "operation": "upsert",
  "item": {
    "id": "1",
    "name": "Upserted Item"
Developer Tools
A Dockerfile and sample flow are provided to test the functionality of the module.
Prerequisites
  • Docker
  • npm
  1. Install module dependencies:
    cd {path/to/repo}
    npm install
  2. Create Docker container:
    cd ./development_tools/docker
    docker-compose up
  3. Access the Node-RED flow at http://localhost:1880/.
GPL 3.0
Version: 2.1.0
Updated 1 year, 3 months ago
License: GPL 3.0
6 in the last week
  • cosmos-r2
  • cosmos
  • database
  • r2
