node-red-contrib-zyre 0.0.1
Node-RED nodes for Zyre - an open-source framework for proximity-based peer-to-peer applications.
npm install node-red-contrib-zyre
Relies on the zyre.js and zeromq packages. Note: The zeromq package can take time to compile if pre-built binaries are not available.
Note: This package has not yet been released. To preview the package, build the package from source:
# Replace the following with your path to node-red
git clone [email protected]/InSourceSoftware/node-red-contrib-zyre.git
Setup
Drag any Zyre node onto the palette to create a zyre peer. Click edit on the Zyre Peer field to set up a new node. The defaults are usually sufficient, but see the following for information about each field.
Name: The name of the zyre peer config node. Note: This also controls the name of the peer itself unless the environment variable ZYRE_PEER_NAMES is set, in which case the actual name is randomly chosen from the comma-delimited list.
Port: The ZRE UDP-beacon broadcast port can be changed if desired to create a new Zyre network.
Evasive: The number of milliseconds before a peer is considered evasive.
Expired: The number of milliseconds before an evasive peer is considered expired. After this long, the expired event is fired.
Interval: The number of milliseconds between UDP-beacon broadcasts. The connect event is fired when new nodes are discovered.
Groups: A comma-delimited list of groups to join on start-up.
Headers: A JSON-string containing key/value headers sent with the ZRE HELLO message for the connected event.
Encoding: The payload encoding of received messages. Defaults to utf8. Available values are: ascii, utf8, utf16le/ucs2, base64, binary, or hex. Use raw to receive raw buffers.
Input
All Zyre nodes can be used for input. For presence nodes (connect, disconnect, expired, join, and leave), the payload is a JSON object containing information about the event. The identifier or name of the peer from the event can be used to send a zyre-whisper (see below).
  • zyre connect: identity, name, headers
  • zyre disconnect: identity, name
  • zyre expired: identity, name
  • zyre join: identity, name, group
  • zyre leave: identity, name, group
For messaging nodes (whisper, shout), the payload is either a JSON object, a string, or a raw buffer (if encoding is set to raw on the zyre peer config node). In addition, the information about the event is sent as additional fields on the msg.
  • zyre whisper: topic, identity, name (topic is the identity of the sender)
  • zyre shout: topic, identity, name (topic is the name of the group)
For input, set the topic to the name of another zyre peer or the name of a group to filter input.
Output
The join, leave, whisper, and shout nodes can be used for output.
  • zyre join: Uses either the topic on the msg, topic on the node, or payload on the msg to join a group.
  • zyre leave: Uses either the topic on the msg, topic on the node, or payload on the msg to leave a group.
  • zyre whisper: Uses either the topic on the msg or topic on the node to whisper another peer on the network. The topic can be set to either the identity or name of the peer.
  • zyre shout: Uses either the topic on the msg or topic on the node to shout to a group.
Version: 0.0.1
Updated 6 years, 11 months ago
License: MPL-2.0
4 in the last week
  • zyre-peer
  • zyre-connect
  • zyre-disconnect
  • zyre-expired
  • zyre-join
  • zyre-leave
  • zyre-whisper
  • zyre-shout
  • zyre
  • zre
  • zeromq
  • zmq
  • libzmq
  • p2p
  • peer
  • peer-to-peer
  • node
