node-red-contrib-zenitel-connect-pro 2.1.1
Node-RED nodes that utilize the Zenitel Connect Pro API
npm install node-red-contrib-zenitel-connect-pro
Zenitel WAMP Node-RED Nodes
Custom Node-RED nodes inside zenitel-wamp-authLWE.js expose Zenitel intercom functionality over WAMP. They are grouped into event (subscriptions), action (commands) and request (state/query) nodes, all sharing the same connection and payload conventions.
Connection & Authentication
  • Use the wamp-client configuration node to define target IP, authId and password. The WAMP port is fixed to 8086 and the node always connects to wss://<ip>:8086 on realm zenitel.
  • TLS 1.2-1.3 is enforced and NODE_TLS_REJECT_UNAUTHORIZED is set to 0, so self-signed Zenitel certificates are accepted.
  • Ticket authentication is implemented by GetToken(), which performs an HTTPS POST /api/auth/login call using HTTP Basic credentials and injects the returned access_token in the WAMP onchallenge handler.
  • Connections are pooled by wampClientPool, so multiple nodes reuse the same Autobahn session; closing a configuration node tears down its pooled session.
Payload & Error Conventions
  • Every action/request node calls ensurePayloadObject so msg.payload is coerced to an object (or an empty object). Arrays can be supplied where explicitly stated (for example, multiple call-forward rules).
  • wrapWampCallPayload mirrors object payloads into both args[0] and kwargs before executing session.call, which keeps Zenitel procedures that expect positional or keyword arguments satisfied.
  • Many nodes accept several aliases for the same field (from_dirno, fromdirno, audio_msg_dirno, etc.). assignConfigValue copies configured defaults into missing payload fields, syncAliases keeps aliases in sync, and findMissingAliases reports missing mandatory groups.
  • When required data is missing or invalid, reportMissing sets the node status to red, writes an error message into msg.error, and forwards the message for downstream diagnostics.
  • Successful WAMP responses overwrite msg.payload with the returned object/array. Rejections keep the original payload but also set msg.error.
Event Nodes (Subscriptions)
Node Topic Purpose Key filters
Zenitel WAMP In config.topic Generic subscriber/registration node None (user supplies topic)
Zenitel GPI Event com.zenitel.device.gpi Emits GPI state changes dirno, GPinput (matching gpiX/gpioX), GPstate
Zenitel GPO Event com.zenitel.device.gpo Emits GPO operations dirno, GPoutput, GPstate
Zenitel Door Open com.zenitel.system.open_door Door open events from any device door_dirno, from_dirno
Zenitel Call State com.zenitel.call Any call setup/connected/ended state fromdirno, todirno, callstate, reason
Zenitel Device State com.zenitel.system.device_account Device registration/online state dirno, exact state (case-insensitive)
Zenitel Event Trigger com.zenitel.system.event_trigger ZCP-defined triggers dirno (from), eventno (to)
Zenitel Extended State com.zenitel.system.device.extended_status Hardware test or health status dirno, testtype, testresult
Notes per event node
  • Zenitel WAMP In: exposes a plain subscribe to any topic you provide. Every message arrives as { topic, payload: { args, kwargs } }.
  • Zenitel GPI Event: normalises filter values so gpi1 equals gpio1. Matches succeed when incoming values include the configured strings, so partial matches are allowed (1001 matches filter 100). Sends raw args & kwargs.
  • Zenitel GPO Event: filters on dirno, id, and operation. The incoming payload is expected at payload.args[0].
  • Zenitel Door Open: builds a payload.data object from either kwargs or args[0] and compares door_dirno/from_dirno. Useful for seeing which station opened which door.
  • Zenitel Call State: extracts fromdirno, todirno, callstate, and reason from any of the typical Zenitel field names (from_dirno, call_state, cause, etc.). Empty filters mean "match everything".
  • Zenitel Device State: recognises dirno, dir_no, or device_id plus state/status/device_state. Case-insensitive equality is used for the state filter.
  • Zenitel Event Trigger: expects Zenitel's event payload layout (from_dirno, to_dirno). Filter strings use String.includes, so you can subscribe to entire ranges/prefixes.
  • Zenitel Extended State: surfaces self-test or monitoring events. payload.data holds harmonised fields (dirno, status_type, current_status), making downstream logic easier.
Most event nodes keep their node status indicator green while the pooled connection is open and switch to red when the connection closes.
Action Nodes (Commands)
Node Procedure Purpose Required payload
Zenitel WAMP Out config.procedure Generic caller for any Zenitel procedure Whatever the target expects
Zenitel Call Setup com.zenitel.calls.post Start or manipulate a call from_dirno, to_dirno; optional priority (defaults 40), action (defaults setup), verbose
Zenitel Play Audio Message com.zenitel.calls.post Start message playback audio_msg_dirno/from_dirno, to_dirno; optional priority, action
Zenitel Door Opener com.zenitel.calls.call.open_door.post Trigger remote door relay for an active call from_dirno (station that owns the call)
Zenitel GPO Trigger com.zenitel.devices.device.gpos.gpo.post Operate a specific GPO dirno, id (GPO), operation (set, clear, slow_blink, fast_blink, set_timed); time required for set_timed
Zenitel Key Press com.zenitel.devices.device.key.post Simulate a button edge dirno, id; optional edge/action (tap default)
Zenitel Setup Call Forwarding com.zenitel.call_forwarding.post Apply one or more call-forward rules Array (or single object) with dirno, fwd_type, fwd_to, enabled
Zenitel Delete Call Forwarding com.zenitel.call_forwarding.delete Remove forwarding rules dirno, fwd_type (unconditional, on_busy, on_timeout, or all)
Zenitel Button Test com.zenitel.system.devices.test.button.post Run the button hardware test dirno
Zenitel Tone Test com.zenitel.system.devices.test.tone.post Run the tone generator test dirno
Zenitel Call End com.zenitel.calls.delete Clear an active call by dirno dirno of the call/device
Zenitel Audio Message End com.zenitel.calls.delete Stop an ongoing audio message dirno of the audio message call leg
Notes per action node
  • Generic WAMP Out: perfect for advanced or not-yet-modelled API calls. Supply the full payload object or array; it will be wrapped automatically.
  • Call Setup / Play Audio Message: both normalise aliases (fromdirno/from_dirno, todirno/to_dirno) and coerce values to strings. Priorities default to 40, and the action defaults to setup unless explicitly overridden (e.g., to pickup, answer, cancel).
  • Door Opener: expects the from_dirno that identifies the current call (typically the answering station). Additional payload keys are preserved and sent to the API.
  • GPO Trigger: operation strings are de-duplicated (e.g., slowblink, slow blink -> slow_blink). Invalid operations or missing time for set_timed raise a validation error via reportMissing.
  • Key Press: alias handling allows edge or action. Accepted edges are whatever the Zenitel API supports (tap, press, release, etc.); unspecified values default to tap.
  • Setup Call Forwarding: accepts either a single object in msg.payload or an array. Merges config/payload aliases for dirno, the forward target (fwddirno/forward_dirno/to_dirno/todirno/fwd_to), and the rule (rule/fwd_type). Boolean strings such as "enable" / "disable" become proper booleans, and errors call out the rule index with missing fields.
  • Delete Call Forwarding: requires a dirno plus fwd_type; setting fwd_type to all removes every rule for that station. The node accepts fwd_type or legacy rule in both config and payload, normalising to fwd_type before the call.
  • Hardware tests & call termination nodes: small wrappers that only require dirno. They are ideal for wiring directly to inject nodes or dashboards.
Request Nodes (Queries)
Node Procedure Description Filters
Zenitel Device Account Request com.zenitel.system.device_accounts Lists device accounts with optional state filtering state (omit or "all"/"*" to fetch everything)
Zenitel Audio Message Request com.zenitel.system.audio_messages Lists available audio messages None
Zenitel Groups Request com.zenitel.groups Retrieves group definitions dirno/groupdirno, verbose
Zenitel Directory Request com.zenitel.directory Pulls directory entries dirno (optional)
Zenitel Call Forwarding Request com.zenitel.call_forwarding Reads forwarding rules dirno, fwd_type (omit/all/* to fetch all types)
Zenitel Current Calls com.zenitel.calls Lists calls matching criteria from_dirno, to_dirno, state, verbose
Zenitel Current Call Queues com.zenitel.call_queues Lists queue members queue_dirno
Zenitel GPO Request com.zenitel.devices.device.gpos Reads GPO state for a device dirno/device_id (required), id/gpo_id (omit/all/* for every output)
Zenitel GPI Request com.zenitel.devices.device.gpis Reads GPI state for a device dirno/device_id (required), id/gpi_id (omit/all/* for every input)
Zenitel WAMP Request config.procedure Generic query node mirroring Zenitel WAMP Out but intended for idempotent reads Whatever the target expects
Notes per request node
  • All request nodes call the associated procedure and forward the returned array/object in msg.payload.
  • Device Account Request: normalises state to lowercase; "all" or "*" removes the filter entirely.
  • Audio Message Request: wraps an empty payload, which Zenitel interprets as "list everything".
  • Groups Request: supports dirno, groupdirno, or a configured default, plus a verbose flag that understands "true"/"false", "yes"/"no", and numeric strings.
  • Directory Request: accepts a single dirno filter; leave blank for all records.
  • Call Forwarding Request: optional dirno/fwd_type filters. Setting fwd_type to "all" behaves the same as omitting it.
  • Current Calls: supports from_dirno, to_dirno, state, verbose. Blank or "*" removes the field from the query.
  • Current Call Queues: optional queue_dirno; blank values fetch all queues.
  • GPO Request: requires a device dirno/device_id and optionally narrows results to a specific output via id/gpo_id. When id is "*", "all", or blank, the node fetches all outputs via the REST API; specific IDs continue to use WAMP.
  • GPI Request: same pattern as GPO Request but targets inputs; "*", "all", or blank triggers a REST fetch of every input, while specific IDs stay on WAMP.
  • Zenitel WAMP Request: the request counterpart to Zenitel WAMP Out, handy for ad-hoc diagnostics or new API endpoints.
Dynamic Subscribe Helper
wamp subs (WampClientSubscribe) is a utility node that subscribes to a topic provided at runtime in msg.topic. It is useful for dashboard-driven subscriptions or for temporarily tapping into seldom-used topics without wiring dedicated nodes.
## Troubleshooting Tips
- Watch the node status dot: green means the pooled Autobahn session is live, red indicates the connection (or authentication) dropped.
- When a field is missing, the node adds a human-readable string to `msg.error`. Consider wiring Debug nodes to both the `msg.payload` and `msg.error` paths.
- Because TLS validation is disabled, always restrict Node-RED access; otherwise credentials could be intercepted by a man-in-the-middle.
- Reuse `Zenitel WAMP Out` / `Zenitel WAMP Request` before adding new specialised nodes - the helper functions already perform aliasing and validation, so you get consistent behaviour.
## License
This project is licensed under the Apache License 2.0.
See the LICENSE file for details.
Version: 2.1.1
Updated 7 months ago
4 in the last week
  • Zenitel WAMP In
  • Zenitel WAMP Out
  • Zenitel Device Account Request
  • Zenitel Audio Message Request
  • wamp subs
  • wamp-client
  • wamp
  • Erik Mortensen
