node-red-contrib-zabbix-sender 1.0.0
Node-RED node to send data to Zabbix server
npm install node-red-contrib-zabbix-sender
About
Send your data to Zabbix using the Zabbix trapper protocol. This node is the wrapper around node-zabbix-sender library.
To send simple item data, send message with following payload:
msg.payload = [
	"webserver",
	"httpd.running",
	0
You can set default hostname in node settings, then you can send just item name and value:
msg.payload = [
    "httpd.running",
    0
You can also send multiple items at once, just construct payload as array of arrays:
msg.payload = [
        "dbserver",
        "mysql.ping",
        1
        "webserver",
        "httpd.running",
        0
Code released under the MIT License. Zabbix logo is used under Zabbix Trademark and Logo Usage Policy.
Version: 1.0.0
Updated 7 years, 5 months ago
Rating: 5.0 2
13 in the last week
  • zabbix-sender
  • zabbix
