node-red-contrib-yoctopuce 1.1.1
Node-RED nodes to interact with Yoctopuce modules.
npm install node-red-contrib-yoctopuce
A Node-RED node to interact with Yoctopuce Sensors.
You can install this node directly from the "Manage Palette" menu in the Node-RED interface. There are no external dependencies or compilation steps.
Alternatively, run the following command in your Node-RED user directory - typically ~/.node-red on Linux or %HOMEPATH%\.nodered on Windows
All node has at least three parameters :
  • YoctoHub: the YoctoHub configuration where the Yoctopuce device is connected (see bellow)
  • Hardware ID: the hardware id of the Yoctopuce function.The Hardware ID can be specified using several formats:
    • FunctionLogicalName
    • ModuleSerialNumber.FunctionIdentifier
    • ModuleSerialNumber.FunctionLogicalName
    • ModuleLogicalName.FunctionIdentifier
    • ModuleLogicalName.FunctionLogicalName
  • Name (optional): the name of this Node-RED node.
The YoctoHub configuration has 4 parameters:
  • YoctoHub Hostname: the hostname or the IP address of the VirtualHub or YoctoHub where the YSensor is connected.
  • YoctoHub Port: the port used by the VirtualHub or YoctoHub (usually 4444).
  • YoctoHub Username (optional): the username to access the VirtualHub or YoctoHub.
  • YoctoHub Password (optional): the password to access the VirtualHub or YoctoHub.
Version: 1.1.1
Updated 8 years, 8 months ago
13 in the last week
  • YFunction
  • YSensor
  • YBuzzer
  • YColorLed
  • YColorLedCluster
  • YCurrentLoopOutput
  • YDigitalIO
  • YDisplay
  • YLed
  • YPwmOutput
  • YRelay
  • YSerialPort
  • YServo
  • YSpiPort
  • YVoltageOutput
  • YWatchdog
  • YSQLHelper
  • YDbSplit
  • yoctohub
