node-red-contrib-xvfb 1.0.0
A simple wrapper of XVFB node
npm install node-red-contrib-xvfb
This Node-Red module wraps the node-xvfb allowing you to run GUI based node modules, e.g. node-red-contrib-nbrowser without having to run X separately.
To install this module you will need to ensure you have installed Xvfb in whatever mechanism makes sense for your host system, i.e. apt, yum, etc. After that you can install this module use Node-Red GUI installer or console command:
Add a "start xvfb" node to your flow before you try to run any GUI modules. To save resources you can also call "end xvfb" when you have finished.
Credits
This was created from code found on the node-red-contrib-nbrowser issues list: https://github.com/Steveorevo/node-red-contrib-nbrowser/issues/17
Version: 1.0.0
Updated 4 years, 11 months ago
2 in the last week
  • start-xvfb
  • end-xvfb
  • xvfb
  • frame-buffer
  • nodered
  • headless
