node-red-contrib-xkeys_lcd 0.3.2
Xkeys LCD node for Node-RED using Dynamic Control Data Protocol (DCDP)
npm install node-red-contrib-xkeys_lcd
This is another in a collection of Node-RED nodes which enable access to X-keys physical devices using Dynamic Control Data Protocol (DCDP).
Dedicated Node-RED nodes for each X-key event of interest (button, jog, joystick, etc.) will communicate, using MQTT, with a lightweight DCDP server, whose sole purpose is to mediate access to any physically attached X-keys devices.
This xkeys_lcd node encapsulates actions for any or specific LCD equiped X-keys devices.
This node requires dcdp-server version 0.1.1 to be running. Please follow the instructions at the dcdp-server development repository to install it or, to upgrade an existing installation, see the dcdp-server upgrade instructions.
The node-red-contrib-xkeys_lcd node itself is best installed from Node-RED's Palette manager. Go to the Palette manager's Install tab and search for node-red-contrib-xkeys_lcd; then Install it once found. If not found, press the Refresh module list button (two semicircular arrows) and search again.
When installed, a new xk LCD node will be found in the palette tab in the dedicated Xkeys category.
The node's configuration editor can be used to set the target Xkeys device, the default line number to write to as well as backlight status.
The msg.payload expected by the xkey_lcd node is as follows:
{ lcdtext: LCDTEXT, linenum: LINENUM, product_id: PID, unit_id: UID, duplicate_id: DUPID }
where
  • LCDTEXT is the text to display. It may be a simple string, number, or array of the two strings to be displayed.
  • LINENUM is 1 or 2, denoting which display line to write to.
  • PID is the product Id of the device
  • UID is the unit Id of the device
  • DUPID is the duplicate Id of the device
Only the lcdtext field is required. The other fields are optional, in which case the default settings (as set in the node configuration editor) for linenum or backlight are used.
An example flow is provided in the examples directory to demonstrate a number of methods to activate the xkeys_lcd node.
  • the first two Inject nodes send "Node-RED" to line 1 and "Hello World!" to line 2 of the display.
  • the next Inject node sends text string ("This is the end") as the msg.payloads, which will be displayed on whichever line has been selected in the node configuration (default is line 2).
  • the fourth Inject node demonstrates how to set both lines of text in the same message.
  • the last three Inject nodes show how to clear all or individual lines of the display.
Issues
When configuring the node, a drop down list of possible devices should be available. If not, instead displaying just a note to Press Deploy button to see device list, first follow that advice. If that is unsuccessful (still no list of possible devices), then check the status of the dcdp-server by running the command sudo systemctl status dcdp-server in a terminal. Typical output of a normally running dcdp-server will be:
pi@pi3b:~ $ sudo systemctl status dcdp-server
● dcdp-server.service - Run dcdp-server as background service
Loaded: loaded (/etc/systemd/system/dcdp-server.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2021-10-14 09:31:55 AEST; 23h ago
whereas a non-running dcdp-server will show something like:
Active: failed (Result: timeout) since Fri 2021-10-15 08:41:37 AEST; 19s ago
If necessary, (re)start the dcdp-server with sudo systemctl restart dcdp-server
Authors and acknowledgment
Many thanks to P.I. Engineering for financial support and donation of several X-keys devices for development and testing.
MIT
Version: 0.3.2
Updated 4 years ago
2 in the last week
  • xkeys_lcd
  • X-keys
  • Xkeys
  • xkeys
  • dcdp
