node-red-contrib-xkeys_button 0.3.3
Xkeys button node for Node-RED using DCDP
npm install node-red-contrib-xkeys_button
node-red-contrib-dcdp_button
This is the first of a group of Node-RED nodes to enable access to X-keys physical devices using the DCD Protocol.
It is planned to have a dedicated Node-RED node for each X-key event of interest (button, jog, joystick, etc.). These will communicate, using MQTT, with a lightweight DCD Protocol server, whose sole purpose is to mediate access to any physically attached X-keys devices.
This dcdp_button node encapsulates button events from any or specific X-keys devices.
This node requires dcdp-server version 0.1.1 to be running. Please follow the instructions at the dcdp-server development repository to install it or, to upgrade an existing installation, see the xkeys-server upgrade instructions.
The node-red-contrib-dcdp_button node itself is best installed from Node-RED's Palette manager. Go to the Palette manager's Install tab and search for node-red-contrib-dcdp_button; then Install it once found. If not found, press the Refresh module list button (two semicircular arrows) and search again.
When installed, a new xk button will be found in the palette tab in a dedicated Xkeys category.
An xkeys_button-test flow is provided in the examples directory using an xkeys_button configured to process button events from any Xkeys device. The output feeds a switch node which routes button events according to the received payload's buttonid. Buttonid 1 goes to switch output 1, buttonid 2 to output 2, ..., buttonid 8 to output 8. Each of those outputs feed into debug nodes named b1, b2, ..., b8. Button events can then be monitored in the Debug messages tab. A button event with buttonid 1 will be reported by debug node b1, buttonid 2 by debug node b2 etc.
The full msg.payload of the dcdp_button node is as follows:
{ device: NAME, vendor_id: VID, product_id: PID, unit_id: UID, duplicate_id: DUPID, control_id: BUTTONID, action: TYPE }
where
  • NAME is an abbreviated name of the source device e.g. XK12JOG, which represents the XK-12 Jog & Shuttle device
  • VID is the Vendor ID of the source device e.g. 1035 for P.I. Engineering (Xkeys)
  • PID is the Product ID of the source device e.g. 1062 for the XK-12 Jog & Shuttle device
  • UID is the Unit ID of the source device, typically 0 from the factory but assignable 0-255
  • DUPID is a server assigned number to distinguish duplicate attached devices (same VID,PID,UID)
  • BUTTONID is the button number which caused the event
  • TYPE is the type of event that occurred. Button events may be either down or up types.
With this output from the dcdp_button node, the switch node in the example flow is able to use the msg.payload.buttonid field to route each event to the corresponding output.
Issues
When configuring the node, a drop down list of possible devices shoud be available. If not, instead displaying just a note to Press Deploy button to see device list, first follow that advice. If that is unsuccessful (still no list of possible devices), then check the status of the dcdp-server by running the command sudo systemctl status dcdp-server in a terminal. Typical output of a normally running xkeys-server will be:
pi@pi3b:~ $ sudo systemctl status dcdp-server
● dcdp-server.service - Run dcdp-server as background service
Loaded: loaded (/etc/systemd/system/dcdp-server.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2021-10-14 09:31:55 AEST; 23h ago
whereas a non-running dcdp-server will show something like:
Active: failed (Result: timeout) since Fri 2021-10-15 08:41:37 AEST; 19s ago
If necessary, (re)start the dcdp-server with sudo systemctl restart dcdp-server
Authors and acknowledgment
Many thanks to P.I. Engineering for generous financial support and donation of several X-keys devices for development and testing.
MIT
Version: 0.3.3
  • xkeys_button
  • X-keys
  • Xkeys
  • dcdp
