node-red-contrib-xiaomi-sensors 1.4.2
zigbee2mqtt payload converter for Xiaomi/Aqua sensors
npm install node-red-contrib-xiaomi-sensors
Xiaomi/Aqara MQTT Sensor Nodes
Installing:
Directly from Github, goto your node_modules directory.
In Docker you should goto /data/node_modules THEN run
npm install marc-gist/node-red-contrib-xiaomi-sensors
To Update: you do the same thing.
OR should hopefully show up in the pallet now its on npm
Requirements:
  1. Zigbee2MQTT (aka z2m) and everything you need to get that runnings :)
  2. MQTT broker, which would be part of setting up Z2M
General Notes:
z2m will send payloads in JSON format to the MQTT broker.
In Node-Red, you create a MQTT node to capture those payloads and feed them into one of the custom nodes.
The goal here is to simplify nodes. I was finding that I had numerous 'function' nodes to deal with the MQTT data
Subflows didn't work well because you lose the ability to have status and debug messages (looking like Node-Red is changing that in v20, and works, but these now add a few more features. Also, you don't have to create your own subflow anymore :)
Version: 1.4.2
17 in the last week
  • door-sensor
  • motion-sensor
  • button_v1
  • button_v2
  • temp-sensor
  • wall-switch
  • water-sensor
  • xiaomi
  • aqara
  • zigbee2mqtt
  • marc-gist
