node-red-contrib-xiaomi-roborock 0.0.2
Xiaomi Roborock Node
npm install node-red-contrib-xiaomi-roborock
NodeRED Xiaomi Roborock Node
This module provides an universal node to send commands to a Xioamo vacuum using the miIO module. A full list of commands can be found here: XiaomiRobotVacuumProtocol
Create a new roborock node and provide connection parameters (hostname, token). Command defaults to find_me and can be changed in node properties or by sending payload.command to this node. Args are passed through.
Example for zoned cleanup:
"command": "app_zoned_clean",
"args": [
        18000,
        20000,
        22000,
        25000,
        1
"jobid": "105"
Implemented Nodes
  • miIO Node
Known Issues
Array cannot be passed via node properties ui editor
If a command needs an array or object to be passed as argument, this cannot be done via the node properties ui editor. A JSON payload needs to be send to the node instead in order to work (see example for zoned cleanup above).
Updating firmware requires restart of NodeRED
After a firmware update the following error occur: "Could not connect to device, token might be wrong". Restarting NodeRED usually solves this issue. Thanks to @readeral
Version: 0.0.2
Updated 7 years, 11 months ago
16 in the last week
  • roborock
  • roborockEvent
  • roborock-config
  • xiaomi
  • roborock
  • miio
  • vacuum
  • BrokenThings
