node-red-contrib-xiaomi-miio 1.0.3
miIO device library for node red
npm install node-red-contrib-xiaomi-miio
Node-red node library for controlling Xiaomi devices. Obviously it uses popular miIO device library.
Supported (was tested with) devices:
  • Xiaomi Switch
  • Xiaomi Cube
  • Xiaomi Motion Detector
  • Xiaomi Window/Door Sensor
  • Xiaomi Temperature and Humidity Sensor
  • Xiaomi Air Purifier
  • Xiaomi Generic Device Listener (see documentation for details)
  • Xiaomi Generic Device (see documentation for details)
Installation:
Usage:
This library uses standard way of detecting all available devices, this means that you have to configure miIO device library if you want to see devices available through Xiaomi Gateway. By default this library will see only IP enabled devices from your local network.
Nodes:
See node Info tab for more details.
Cube Node:
Cube Node
Air Purifier Node:
Air Purifier Node
Temperature and Humidity Sensor Node:
TH Node
Window/Door Sensor Node:
Magnet Node
Motion Sensor Node:
Motion Node
Switch Node:
Switch Node
Generic Properties Reader Node:
Generic Node
Listener Node:
Listener Node
Version: 1.0.3
Updated 6 years, 6 months ago
23 in the last week
  • miio-switch
  • miio-cube
  • miio-motion
  • miio-magnet
  • miio-sensor-ht
  • miio-generic
  • miio-air-purifier
  • miio-listener
  • miio-devices
  • miio-tokens
  • miio
  • mi
  • mijia
  • aqara
  • xiaomi
