node-red-contrib-xiaomi-gateway 1.0.10
Node-red blocks for Xiaomi gateway
npm install node-red-contrib-xiaomi-gateway
Package node-red-contrib-xiaomi-gateway
The package is only for use on xiaomi gateways running OpenWRT
Nodes:
  • gateway-button
  • gateway-led
  • gateway-led-notify
  • gateway-illuminance
gateway-button
Receiving events from an embedded button. Returns an object:
{"action": "click", "multiclick": 1}         // one click
{"action": "multiclick", "multiclick": 3}    // three clicks
{"action": "hold", "multiclick": 1}          // hold
gateway-led
Before using the backlight control node, you need to configure the control paths of the LED devices. You can change the paths at any time. Sometimes this is relevant when updating the operating system.
Controls the built-in backlight. Accepts data in the payload field, the data type is configured in the node.
payload = "on";                     // state
payload = "off";
payload = "toggle";
payload = "ff00ff";                 // hex color
payload = {r: 0, g: 0, b: 100};     // object color
gateway-led-notify
The notification node allows you to create various light notifications using the built-in LEDs. Three colors with indices are available for customization (1, 2, 3, 0 - no light). You can also configure the duration of the notification and the duration of the pattern step.
payload = "any type";                           // triggers an alert for a specific period
payload = "start";                              // triggers an alert before manual stop
payload = "stop";                               // stop alert
gateway-illuminance
Receives data from the built-in light sensor. Returns data depending on the settings of the node:
payload = 3059;                                 // raw data from sensor
payload = 36;                                   // converted value, in lux
payload = "day";                                // day or night event
payload = "night";
payload = {raw: 3059, lux: 36, state: "day"};   // full data
Version: 1.0.10
Updated 5 years, 6 months ago
15 in the last week
  • gateway-button
  • gateway-led
  • gateway-led-config
  • xiaomi
  • gateway
