node-red-contrib-ws281x 1.0.0
Node-RED nodes to control WS281x LEDs on a Raspberry Pi
npm install node-red-contrib-ws281x
npm downloads Node-RED License: MIT
Node-RED nodes to control WS281x (Neopixel) LEDs on a Raspberry Pi.
This package provides nodes to interface with rpi-ws281x-native, a library that provides native bindings to the rpi_ws281x library by Jeremy Garff.
Note: This will only work on a Raspberry Pi and requires running Node-RED with root privileges (except for SPI interface).
Important: As of 31 Jan 2022 the Node-RED community encourages scoped package names for newly-published nodes (Packaging guidelines).
This module predates that change, so the un-scoped name remains available for backwards-compatibility.
If you are forking or creating a brand-new package we recommend publishing it as @your-scope/node-red-ws281x (or similar) and replacing the command below accordingly.
npm install node-red-contrib-ws281x # or: npm install @your-scope/node-red-ws281x
Interface Options
This package supports three different interfaces for controlling WS281x LEDs:
šŸŽÆ PWM (Default)
  • GPIO Pins: 12, 18 (only these available on Pi 4B)
  • Pros: Standard interface, well-tested
  • Cons: Conflicts with analog audio
  • Setup: Disable audio in /boot/config.txt with dtparam=audio=off
⭐ PCM (Recommended for Audio Users)
  • GPIO Pin: 21 (Physical pin 40)
  • Pros: Keeps analog audio working, good performance
  • Cons: Conflicts with I2S digital audio devices
  • Best for: Users who need analog audio output
šŸš€ SPI (Highest Performance)
  • GPIO Pin: 10 (SPI0 MOSI)
  • Pros: Lowest CPU usage (1% vs 5%), no root required*, both analog and digital audio work
  • Cons: Requires SPI bus exclusive access
  • Setup Required: See SPI configuration below
SPI Interface Setup
For SPI interface (recommended for performance):
Pi 4B Configuration:
# Add to /boot/cmdline.txt (append to existing line)
spidev.bufsiz=32768
# Add to /boot/config.txt
core_freq=500
core_freq_min=500
Pi 3B Configuration:
spidev.bufsiz=32768
core_freq=250
User Permissions:
sudo usermod -a -G gpio pi
*SPI interface doesn't require root when user is in gpio group.
This package provides two nodes:
  • ws281x-config: A configuration node to initialize the LED driver.
  • ws281x-output: An output node to send color data to the LEDs.
  1. Add a ws281x-output node to your flow.
  2. In the node's properties, click the pencil icon to add a new ws281x-config controller.
  3. Select your preferred interface (PWM/PCM/SPI) and configure:
    • 60 LEDs: Set LED count to 60
    • PCM Interface: Select PCM, GPIO will auto-set to 21
    • SPI Interface: Select SPI, GPIO will auto-set to 10
  4. Deploy the flow to initialize the driver.
Sending Data
The ws281x-output node accepts various msg.payload formats:
String Commands
  • "clear": Sets all LEDs to black.
  • "render" or "show": Sends the current color data to the LEDs.
  • Any CSS color string (e.g., "red", "#ff0000"): Fills the entire strip with that color.
Example:
{ "payload": "red" }
Numeric Color
A number representing a 24-bit RGB colour in the form 0xRRGGBB (e.g. 0xff0000 for red).
āš ļø Important: Do not include an alpha byte – values like 0xff0000ff (RGBA) will produce incorrect colours on the strip.
Example:
{ "payload": 16711680 }
Object Payloads
For more specific control, you can send an object:
  • Set a single pixel: { "index": 5, "color": "blue" }
  • Set multiple pixels: { "pixels": [0xff0000, 0x00ff00, 0x0000ff] }
  • Change brightness: { "brightness": 128 }
  • Prevent immediate rendering: { "pixels": [...], "render": false }
Prerequisites
  • A Raspberry Pi with Raspbian or a similar OS.
  • Node.js and Node-RED installed.
  • External 5V power supply for 60 LEDs (5A+ recommended)
  • Logic level shifter (74AHCT125 or similar) for 3.3V→5V conversion
Performance Comparison
For 60 LEDs on Pi 4B:
Interface CPU Usage Audio Compatibility Root Required
PWM 5% āŒ Conflicts āœ… Yes
PCM 5% āœ… Analog only āœ… Yes
SPI 1% āœ… Both types āŒ No*
*When user is in gpio group
Example Configuration
For PCM (keeps analog audio):
  "interface": "PCM",
  "gpio": 21,
  "leds": 60,
  "brightness": 150
For SPI (best performance):
  "interface": "SPI",
  "gpio": 10,
  "leds": 60,
  "brightness": 150
This project is licensed under the MIT License.
SPI Interface Detailed Analysis
Pros:
  • Superior Performance: Lowest CPU usage (~1% vs 5% for PWM/PCM) - hardware-driven timing
  • Audio Compatibility: Both analog AND digital audio work perfectly - no conflicts with audio subsystems
  • System Stability: No root privileges required when user is in gpio group, more predictable timing
  • Mature Implementation: Well-established protocol with hardware acceleration via dedicated SPI controller
Cons:
  • Hardware Limitations: Single GPIO pin only (GPIO 10), shared SPI bus conflicts with other SPI devices
  • Setup Requirements: SPI interface must be enabled via raspi-config, slightly more complex configuration
  • Protocol Constraints: Fixed timing ratios, each WS2812 bit requires 3 SPI bits encoding
References:
Open-Source, Naming & Packaging
This project follows the official Node-RED packaging best-practices:
  • node-red is included in the keywords field of package.json so the node can be discovered in the palette manager.
  • A valid node-red block declares the runtime files for the flow engine.
  • The repository is licensed under the permissive MIT License making it suitable for both private and commercial use.
  • Continuous integration is provided by the public test-suite (npm test) so you can verify behaviour after every contribution.
If you intend to publish your own fork to npm please ensure you:
  1. Use a scoped name such as @my-org/node-red-awesome.
  2. Include a clear README.md, LICENSE, and at least one example flow (see examples/ in the docs).
  3. Validate the package locally with npx node-red-dev validate to achieve a green Node Scorecard before releasing.
By following these steps your node will be eligible for inclusion in the Node-RED Flow Library and receive a public scorecard that helps users judge quality and maintenance status.
Version: 1.0.0
Updated 1 year, 6 months ago
  • ws281x-config
  • ws281x-output
  • raspberry-pi
  • rpi
  • ws281x
  • ws2812
  • neopixel
  • led
  • gpio
  • pwm
  • pcm
  • spi
