node-red-contrib-woocommerce 0.3.2
Communication nodes to an instance of woocommerce
npm install node-red-contrib-woocommerce
Interface to WooCommerce
Single node that currently allows GET, POST and PUT methods to an instance of Woocommerce.
Getting started
Generate API credentials (Consumer Key & Consumer Secret) following this instructions http://docs.woocommerce.com/document/woocommerce-rest-api/ .
Check out the WooCommerce API endpoints and data that can be manipulated in http://woocommerce.github.io/woocommerce-rest-api-docs/.
Supports:
msg.endpoint - the various endpoints as documented above msg.params - various query parameters. msg.payload - data to be sent to WooCommerce - No payload required for GET/DELETE/OPTIONS Method.
This is basically a wrapper around the Node API https://www.npmjs.com/package/woocommerce-rest-ts-api
So please follow the examples there.
Example nodes included
Credits
As mentioned this is basically just a node red wrapper around the node wrapper for the WooCommerce API. Original version was by the WooCommerce team.
https://github.com/woocommerce/woocommerce-rest-api-js-lib
but had not been updated for the last 2 years. Then I found an recently updated version which fixed many dependencies by Yuri Lima https://www.npmjs.com/package/woocommerce-rest-ts-api
Version: 0.3.2
Updated 3 years, 9 months ago
2 in the last week
  • woocommerce-config
  • woocommerce
  • woocommerce
