node-red-contrib-wmi 0.2.8
Node-RED node for wmi
npm install node-red-contrib-wmi
A node to retrieve WMI (Windows Management Instrumentation) object on Windows OS
Information
This node retrieves the information of the WMI object on Windows OS. Currently, this node supports the following objects in the pull-down menu on the node property UI.
If you want to get other WMI objects, you can specify the object name in msg.object.
Inputs
  • object - string
    WMI object name (optional)
Outputs
  • payload - object
    WMI object in JSON format
Note: This node can be used on the Windows OS only.
Version: 0.2.8
Updated 2 years, 11 months ago
Rating: 5.0 2
1 in the last week
  • node-red-nodegen
  • wmi
  • windows
