node-red-contrib-whois-parser 1.0.8
nodered node to make whois requests based on ruby whois gem (via cmd exec, requires ruby installation)
npm install node-red-contrib-whois-parser
this node requires Ruby and following ruby gems: json, whois, whois-parser installed on the server running nodered
  apt install ruby-full rubygems
  gem install json whois whois-parser
Troubleshooting
in case you are working with nodered in docker container, you may need the root access to install ruby.
docker exec will allow you to login as root
docker exec -u 0 -it mynodered bash
then you can install ruby with
  apk update
  apk add ruby-full
Links
Version: 1.0.8
Rating: 5.0 2
  • whois-parser
  • nodered
  • whois
  • ruby
  • whois-parser
