node-red-contrib-whatsapp-api 0.1.2
Node-RED nodes for WhatsApp Web automation over Baileys.
npm install node-red-contrib-whatsapp-api
Node-RED nodes for driving a WhatsApp Web session with Baileys.
What it includes
  • whatsapp-api-config: stores reconnect settings and the local runtime data directory
  • whatsapp-api-in: emits normalized incoming WhatsApp messages
  • whatsapp-api-send: sends text or media to a chat
  • whatsapp-api-history: reads recent messages from the local persisted store
Runtime requirements
  • Node.js 20+
  • Node-RED 4+
  • A phone that can scan the WhatsApp Web QR code
Install locally
npm install
npm run build
npm install /absolute/path/to/node-red-contrib-whatsapp-api-0.1.0.tgz
Then restart Node-RED and add the whatsapp-api nodes from the palette.
The packed module ships as a bundled runtime, so target installs do not need to rebuild or reshuffle the Baileys dependency tree on the Node-RED host.
Install from npm
After the package has been published:
Login flow
This palette uses a deploy-first QR flow.
  1. Add a whatsapp-api-config node and deploy the flow.
  2. Open the config node again in the editor.
  3. Click Connect.
  4. Scan the QR code with WhatsApp on your phone.
  5. Wait for the status to show Connected.
The runtime keeps its auth state on disk and now attempts to reuse it automatically after every Node-RED restart. Use Disconnect to clear the stored session and force a fresh QR login.
Local message history
whatsapp-api-history reads from a local JSON store that is updated by the connected runtime. It returns messages the session has already synced or seen. It is not a server-side fetch of arbitrary WhatsApp chat history.
The history node can also return only the newest incoming messages that the linked WhatsApp account still has unread for the selected chat.
Example Node-RED flow
Import this JSON from the Node-RED editor (Menu -> Import -> Clipboard) to get a starter flow with:
  • one whatsapp-api-config node
  • one whatsapp-api-send example
  • one whatsapp-api-in listener
  • one whatsapp-api-history example
Replace the sample peer with a real WhatsApp JID such as [email protected].
    "id": "a1f4d7c2e9b00101",
    "type": "tab",
    "label": "WhatsApp Example",
    "disabled": false,
    "info": ""
    "id": "b2f4d7c2e9b00102",
    "type": "whatsapp-api-config",
    "name": "My WhatsApp",
    "reconnectMinMs": "2000",
    "reconnectMaxMs": "30000",
    "dataDir": ""
    "id": "c3f4d7c2e9b00103",
    "type": "inject",
    "z": "a1f4d7c2e9b00101",
    "name": "Send test message",
    "props": [
        "p": "payload"
    "payload": "hello from Node-RED",
    "payloadType": "str",
    "x": 170,
    "y": 100,
        "d4f4d7c2e9b00104"
    "id": "d4f4d7c2e9b00104",
    "type": "whatsapp-api-send",
    "name": "Send WhatsApp",
    "account": "b2f4d7c2e9b00102",
    "peer": "[email protected]",
    "x": 450,
    "y": 100,
        "e5f4d7c2e9b00105"
    "id": "e5f4d7c2e9b00105",
    "type": "debug",
    "name": "Send result",
    "active": true,
    "tosidebar": true,
    "complete": "true",
    "targetType": "full",
    "x": 720,
    "y": 100,
    "id": "f6f4d7c2e9b00106",
    "type": "whatsapp-api-in",
    "name": "Incoming messages",
    "includeRaw": false,
    "x": 190,
    "y": 200,
        "07f4d7c2e9b00107"
    "id": "07f4d7c2e9b00107",
    "type": "debug",
    "name": "Incoming debug",
    "active": true,
    "tosidebar": true,
    "complete": "true",
    "x": 470,
    "y": 200,
    "id": "18f4d7c2e9b00108",
    "type": "inject",
    "name": "Read last 5",
    "props": [
        "p": "payload"
    "payload": "",
    "payloadType": "date",
    "x": 150,
    "y": 300,
        "29f4d7c2e9b00109"
    "id": "29f4d7c2e9b00109",
    "type": "whatsapp-api-history",
    "name": "Recent Chat History",
    "limit": "5",
    "x": 450,
    "y": 300,
        "3af4d7c2e9b0010a"
    "id": "3af4d7c2e9b0010a",
    "type": "debug",
    "name": "History debug",
    "active": true,
    "tosidebar": true,
    "complete": "true",
    "x": 730,
    "y": 300,
Message contract
Incoming and action nodes use this shape:
  • msg.payload: the main payload for the node
  • msg.whatsapp: normalized WhatsApp metadata
Common metadata fields:
  • msg.whatsapp.peer: { id, type, title, ref }
  • msg.whatsapp.chatId
  • msg.whatsapp.senderId
  • msg.whatsapp.messageId
  • msg.whatsapp.media
  • msg.whatsapp.raw when the node is configured with Include Raw
Send node input patterns
Text only:
  "whatsapp": {
Media with a file path:
  "payload": "daily report",
  "whatsapp": {
    "mediaPath": "/tmp/report.pdf"
Media with a Buffer:
msg.payload = Buffer.from("file-bytes");
msg.whatsapp = {
  peer: "[email protected]",
  fileName: "image.jpg",
  caption: "generated by a flow",
  mimeType: "image/jpeg"
Version: 0.1.2
Updated 8 months ago
License: UNLICENSED
Rating: 0.0
94 in the last week
  • baileys
  • node-red-contrib
  • whatsapp
  • whatsapp-web
