node-red-contrib-websocket-server 0.0.9
websocket test with websocket open/close event information
npm install node-red-contrib-websocket-server
Node-red Apache2 Websocket
Node for run Websocket server with some aditional features
Based on Node-Red inbuild websocket node
Websocket_server
Settings:
  • Path - Websocket server address
    ws(s)://<your node-red address>:<node-red Port>/"Path"
  • Send/Receive - msg format
    • payload - only msg.paylod will be processed
    • Entire message - full msg object will be processed
  • Ping action
    • none - Automatically answer on Ping request from Client
    • Send ping - Server send ping every x seconds (require "Send ping interval" option >0)
    • Receive ping - Server is waiting for incoming ping from Client. If interval between two ping requests is greater than x seconds (require "Receive ping timeout" option >0) connection will be closed by server.
Websocket_in - node for receive websocket messages
  • Path - You can connect it to already existing server Path or create new server
  • Name - Optional Node Name
Websocket_out - node for send websocket messages
    Input - require msg object with .payload
    Optional - msg._session
    • to send message to group of clients msg._session = [client1_id, client2_id, ...]
    • to send message to one client msg._session = client_id or msg._session.id = client_id
    • if no msg_session, message is sent to all connected clients
Websocket_Open/Close - Information node about connection status
    Output - {msg.event : open or close, msg._session : {id : websocket id, type : 'websocket'}}
Websocket_Drop - node to forcefully close websocket by id
    Input - require msg object with ._session.id
TODO
  • Clean code
  • Add tips in nodes
  • In Websocket_Open/Close add reason for close event
Version: 0.0.9
Updated 7 months ago
Rating: 1.0 1
20 in the last week
  • websocket_Open/Close
  • websocket_Drop
  • websocket_in
  • websocket_out
  • websocket_server
  • websocket
  • open/close
  • server
