node-red-contrib-wavenet 3.1.2
Easily convert text to speech using Google Wavenet voices on Node-RED.
npm install node-red-contrib-wavenet
A Node-RED custom node to convert text to speech using Google Wavenet voice.
Update: Now with 60+ voices with options to adjust speaking rate, pitch, volume, sample rate and audio encoding.
Latest languages added:
  • Added Arabic voices
  • Added Danish voices
Wavenet voice represents a new way of creating synthetic speech, using a WaveNet model, the same technology used to produce speech for Google Assistant, Google Search, and Google Translate.
Takes a string as an input. Returns a base64 encoded array buffer. Attach a file node to save it as an audio file on your disk.
main flow
Sign in to Google Developer Console to get a Speech API key.
Inputs
Payload (string)
  • Use SSML elements in your text to give it more personality. You can use all elements found here.
Voice (string)
  • Choose a specific voice or random
Speaking rate (number | 0.25 to 4.0)
  • In the range of 0.25 to 4.0. 1.0 is the normal native speed. 2.0 is twice as fast, and 0.5 is half as fast.
Pitch (number | -20 to +20)
  • In the range -20.0 to 20.0. 20 means increase 20 semitones from the original pitch. -20 means decrease 20 semitones from the original pitch.
Volume (number | -6 to +6)
  • A value of -6.0 (dB) will play at approximately half the amplitude and a value of +6.0 (dB) will play at approximately twice the amplitude of the normal native signal.
Sample rate (number)
  • The synthesis sample rate (in hertz). When this is specified, the synthesizer will honor this request by converting to the desired sample rate. Default is 24000.
Audio encoding (string)
  • The encoding format of the audio byte stream can be MP3, LINEAR16 or OGG_OPUS
Output
payload (string | base64)
  • A base64-encoded string that is wrapped in containers according to the encoding specified.
Version: 3.1.2
Updated 6 years, 11 months ago
138 in the last week
  • wavenet
  • wavenet-config
  • wavenet
  • tts
  • text-to-speech
  • voice
  • speech
