node-red-contrib-wave-core 0.1.3
Core nodes for integrating Wisenet WAVE VMS into Node-RED
npm install node-red-contrib-wave-core
Core nodes for integrating Wisenet WAVE VMS into Node-RED.
Restart Node-RED after installation.
  • Create login Session (wave-core): Logs into WAVE VMS via /rest/v3/login/sessions, supports cloud relay and local server, stores token optionally in flow context.
  • Delete login Session (wave-delete-session): Deletes an existing session token via /rest/v3/login/sessions, supports cloud/local routing and optional flow token cleanup.
Common options (can be set in the editor or via msg):
  • useCloud / cloudSystemId: Route via WAVE Sync relay ({id}.relay.vmsproxy.com).
  • useLocal / server: Direct server URL/host (https).
  • username, password (login).
  • token / tokenFlowKey (logout).
  • timeoutMs: Per-request timeout in ms.
  • setCookie / storeTokenToFlow / clearTokenFromFlow: Cookie and flow-token handling.
Example Flow (outline)
  1. Inject credentials → Create login Session → store msg.token / flow token.
  2. Do your calls using the token.
  3. Delete login Session with msg.token (or flow token) to clean up.
Development
  • Node entry files: wave-core.js, wave-delete-session.js
  • UI definitions: wave-core.html, wave-delete-session.html
  • Icon: icons/wave.png
To verify publish contents:
npm pack --dry-run
Version: 0.1.3
Updated 11 months ago
  • wave-config
  • wave-core
  • wave-delete-session
  • wisenet
  • wave
  • vms
  • video
  • surveillance
