node-red-contrib-wav-stft 0.1.0
A Node-RED node to decode wav file and perform short-term Fourier transform (STFT)
A Node-RED node to decode audio in WAV format and perform short-term Fourier
transform (STFT). It computes the STFT based on the Window Size and
Stride Size settings. The audio WAV should come in as Buffer data type
from previous node. Here are the processing procedures:
- Slice the whole audio into fix duration segments according to the
Window Sizevalue. TheStride Sizedecides the interval between adjacent segments. - Compute the STFT and frequency bins is 161
- Insert a size 1 rank as the first rank and last rank
Prerequisite
For Tensorflow.js on Node.js
(@tensorflow/tfjs-node
or
@tensorflow/tfjs-node-gpu),
it depends on Tensorflow shared libraries. Putting Tensorflow.js as the
dependency of custom Node-RED node may run into a situation that multiple
custom nodes install multiple tfjs-node module as their dependencies. While
loading multiple Tensorflow shared libraries in the same process, the process
would abord by hitting protobuf assertion.
Therefore, this module put @tensorflow/tfjs-node as peer dependency. You need
to install it with the Node-RED manully.
Install @tensorflow/tfjs-node:
npm install @tensorflow/tfjs-node
Install this module:
Once you install the peer dependency, you can install this module:
npm install node-red-contrib-wav-stft
