node-red-contrib-watchdirectory 1.1.0
A file watcher node for [Node-RED](https://nodered.org/), based on [chokidar](https://github.com/paulmillr/chokidar), initially created by [fatoldsun00](https://github.com/fatoldsun00) and now maintained by [Paprikawurst](https://github.com/Paprikawurst)
npm install node-red-contrib-watchdirectory
A file watcher node for Node-RED, based on chokidar, initially created by fatoldsun00 and now maintained by Paprikawurst.
Why does this node exist?
  • Files are complete when the event fires: the node uses chokidar's awaitWriteFinish, so an event is only sent once the file size has been stable for about 2 seconds. No extra delay or RBE nodes are needed to avoid half-written files.
  • Standard message format: the full path is set as msg.filename, which is what most Node-RED file nodes expect.
  • Filtering: ignore files with a regular expression and limit the depth of subfolders to watch.
  • Watch for created, updated or deleted files (one event type per node)
  • Configurable folder depth
  • Regex to ignore files by name
  • Folder can be a string, flow/global variable, environment variable or JSONata expression
  • Option to ignore files that already exist when the node starts
  • Polling-based, so it also works on network drives and Docker volumes
Only files are reported. Directory events (added or removed folders) are not sent.
Output
Each event sends one message:
Property Type Description
msg.file string File name with extension, e.g. report.xlsx
msg.filedir string Directory of the file
msg.filename string Complete path to the file
msg.payload string Same as msg.filename
msg.size number File size in bytes (always 0 for delete events)
  "file": "report.xlsx",
  "filedir": "C:\\Users\\data\\reports",
  "filename": "C:\\Users\\data\\reports\\report.xlsx",
  "payload": "C:\\Users\\data\\reports\\report.xlsx",
  "size": 45632
Folder (required)
The directory to watch. The type selector next to the field supports:
  • string: a path such as C:\data\incoming or /var/data/incoming
  • flow / global: the name of a context variable, e.g. watchPath
  • env: the name of an environment variable, e.g. DATA_DIR (without ${})
  • JSONata: an expression that returns the path
The value is evaluated once when the flow is deployed or started. Changing a variable later does not change the watched folder until the node is redeployed.
Type events (required)
  • Create: a new file appeared
  • Update: an existing file was modified
  • Delete: a file was removed
Use several nodes if you need more than one event type.
Ignore files (regex, optional)
A regular expression for files that should be ignored. It is tested against the file name only (not the full path). Enter the pattern without the / delimiters.
Pattern Ignores
^\. hidden files such as .gitignore
\.tmp$ files ending in .tmp
^~\$ Office lock files such as ~$a.docx
~$ backup files ending in ~, e.g. a.txt~
\.(log|bak)$ files ending in .log or .bak
^~\$|^\.|\.tmp$ Office lock files, hidden files and .tmp files
(In the table, \| is only Markdown escaping for the pipe character. Type a plain | in the node.)
The pattern is also applied to the name of the watched folder itself, so a pattern like ^\. will ignore everything if the watched folder is called .data.
Depth (number)
How many levels of subfolders are watched:
  • 0 (default): only files directly in the folder
  • 1: the folder and its direct subfolders
  • 2 and higher: further levels
There is no "unlimited" option. Use a high number if you need it. An empty field behaves like 0.
On start ignore files in folder (checkbox)
  • Checked (default): files that already exist when the node starts are ignored. Only changes after the start produce events.
  • Unchecked: existing files are reported as created when the node starts, which is useful for processing a backlog.
This only affects create events.
Status
Status Meaning
yellow ring Listening... Initial scan finished; shown once, 10 seconds after the scan
green dot add/update/delete <file> Last detected event; stays until the next event
red dot Error : <message> The watcher reported an error (also logged via node.error)
Tips
  • Ignore temporary files. Applications often create temporary files while saving, e.g. ^~\$|\.tmp$|\.swp$.
  • Keep depth low. The node polls every watched file, so watching many files or very broad folders (C:\, /) is expensive. Watch the most specific folder you can.
  • Update events can repeat. If an application saves a file several times, you get one update event per save. An RBE node or a delay can reduce duplicates.
Troubleshooting
No events
  • Check that the folder exists and is readable by the Node-RED process.
  • With "On start ignore files" checked, files that existed before deployment are not reported.
  • Check the selected event type.
  • Check that the ignore regex is not too broad and has no / delimiters.
  • Look at the debug panel / Node-RED log for errors.
Events are delayed This is expected: the node waits about 2 seconds for the file size to be stable, and polling adds a little more.
Multiple events for one file The writing application most likely saves the file more than once. See the tips above.
Technical details
The node calls chokidar with these notable options:
  • awaitWriteFinish: true: wait until the file size is stable (chokidar default: 2000 ms)
  • usePolling: true: works on network drives and Docker volumes, at the cost of some CPU
  • binaryInterval: 1000: polling interval in ms for binary files
  • alwaysStat: true: file stats (used for msg.size) are always available
  • ignoreInitial and depth come from the node configuration
Requirements
Via the palette manager
Menu → Manage palette → Install → search for node-red-contrib-watchdirectory.
Via npm
Then restart Node-RED.
Contributing
Pull requests are welcome. For larger changes please open an issue first. Bugs and feature requests go to the issue tracker.
ISC
Links
Version: 1.1.0
Updated 1 month ago
Rating: 4.0 4
64 in the last week
  • watch-directory
  • nodered
  • node red
  • file watcher
  • file watch
  • folder watcher
  • watch folder
  • directory
  • watcher
  • watch
