node-red-contrib-waservix 1.0.0
Node-RED nodes for WAservix: send WhatsApp messages from your own number and react to incoming messages and status updates.
Node-RED nodes for WAservix, the WhatsApp API gateway that sends from your own number.
WAservix links your WhatsApp number by QR code (the same way WhatsApp Web does). These nodes send text, images, documents, locations and polls from any flow, and react to incoming messages and status updates: alerts from Home Assistant or sensors, order notifications, chatbots and more.
In Node-RED: Menu → Manage palette → Install, search for node-red-contrib-waservix.
Or from your Node-RED user directory (usually ~/.node-red):
npm install node-red-contrib-waservix
Needs Node-RED 3.0+ and Node.js 18+. No other dependencies.
Setup
- In the WAservix dashboard, add your number under Devices and scan the QR code with WhatsApp.
- Copy the number's API key.
- Add any WAservix node to a flow, open it, and create a WAservix config node with the key.
waservix send
Sends a WhatsApp message to a number or a group (JID ending in @g.us).
msg.payloadas a string: sent as text (or set Text in the node)msg.payloadas an object: sent as the full API body, e.g.{ "poll": { "name": "Lunch?", "options": ["Pizza", "Sushi"] } }msg.to: the recipient (or set To)- media:
msg.imageUrl,msg.videoUrl,msg.audioUrl,msg.documentUrlwithmsg.captionandmsg.fileName msg.location = { latitude, longitude, name },msg.replyTo,msg.mentions
Output: msg.payload = { msgId, jid, status: "in_progress" }. Messages are queued and sent one at a time per number.
waservix api
Calls any endpoint of the WAservix API and returns its data: for example GET /status, GET /on-whatsapp/+15551234567, GET /messages/58213/info, PUT /messages/58213 (edit), GET /groups, GET /contacts.
waservix webhook
Receives incoming messages, status updates, reactions, calls and session events, and rejects requests whose X-Webhook-Signature does not match your number's webhook secret.
[http in POST /waservix] → [waservix webhook] → your flow
↘ output 2 → [http response]
Set https://<your-node-red>/waservix as the webhook of your number in the WAservix dashboard, paste the secret into the node and optionally filter events (messages.received, messages-personal.received, messages-group.received, messages.update, session.status, ...). msg.topic is the event name.
Errors from the send and api nodes can be caught with a catch node: msg.error holds status, message and errors. A 503 means the number is reconnecting.
Example
Import Menu → Import → Examples → node-red-contrib-waservix → send-whatsapp: an inject node that sends a test message, and a webhook flow that logs incoming messages.
Use it responsibly
WAservix is not Meta's official WhatsApp Business Platform. There's no business verification and no per-conversation fee, but WhatsApp's spam rules apply to your number directly. Message people who expect to hear from you, warm up new numbers slowly and keep the built-in account protection on.
More from Tekservix
- SMS Gora SMS Gateway: SMS through your own Android phones, also for Node-RED (
node-red-contrib-smsgora) - AI Sales Agent: answers customers on WhatsApp and SMS using your website's content
- Website to App: turn your website into Android and iOS apps
- WAservix libraries for 12 languages and n8n nodes: github.com/TekservixHQ
MIT
