node-red-contrib-wago-cc100 0.1.0
Handle EA's on CC100 PLC
npm install node-red-contrib-wago-cc100
Node-Red library to controll EA's on CC100
Directly read and set the Digital In- Outputs and also Analog In- Outputs.
Note: This lib works asynchron!
Controll Digital and Analog signals: Digital EA Analog EA
Download example flow from Github:
https://github.com/Helmut-Saal/CC100-Node-Red/blob/master/Flow%20Example.txt
Note: You have to run the Node-Red Container with privileged mode:
docker run -d --name wago-node-red \
-d --privileged=true --user=root \
-p 1880:1880 \
-v node_red_user_data:/data \
nodered/node-red
Version: 0.1.0
Updated 4 years, 7 months ago
6 in the last week
  • Set-DO1
  • Set-DO2
  • Set-DO3
  • Set-DO4
  • Read-DO
  • Read-DI
  • Set-AO1
  • Set-AO2
  • Read-AO
  • Read-AI1
  • Read-AI2
  • Read-PT1
  • Read-PT2
  • wago
  • CC100
  • Helmut Saal
  • Jens Sparmann
  • Kurt Braun
  • Jesse Cox
  • Sarah Secci
