node-red-contrib-voltage_undivider 0.8.9
A Node to un-divide a voltage that was divided prior to taking a reading to protect a input when reading its value.
npm install node-red-contrib-voltage_undivider
Node-RED A Node to un-divide a voltage that was divided prior to taking a reading to protect a input when reading its value.
Table of Contents
Install with node-red Palette Manager or,
Run the following command in your Node-RED user directory - typically ~/.node-red:
A Node to un-divide a voltage that was divided prior to taking a reading to protect a input when reading its value. Just insert the node in between two others. Then the voltage received can be corrected, undivided, to show voltage before the physical voltage devider.
Property
Define the msg property name you wish. The name you select (msg.example) will also be the output property
The payload must be a number! Anything else will try to be parsed into a number and rejected if that fails.
Voltage_In
Select the voltage scale for the Input. Voltages from diffrent sources may be represented in diffrent scales. Example; a ADC (Anolog to Digital Converter may output in mV. You must select the correct input voltage scale or your output will be wrong.
Resistor_1
Select the resistor scale for the resistor used. Then enter the resistance.
Resistor_2
Voltage_Out
Select the voltage scale you want for the Output. If you have selected the correct scale on the input the output scale you have selected will be automaticly converted to the voltage you want.
Round_Output
If you would like your output to be rounded then select the level you want. Note: if you choose not to round the maximum integer length is 15 digits. The maximum length after a decimals is 17 digits.
Example Flows
Simple examples showing how to use the voltage_undivider.
Example
[{"id":"6c3f0ba9.131de4","type":"change","z":"7edb64d7.2216cc","name":"Anolog Digital Converter","rules":[{"t":"set","p":"payload","pt":"msg","to":"3.25","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":320,"wires":[["5ad1bd27.e1b3b4"]]},{"id":"c0a340e7.a8288","type":"debug","z":"7edb64d7.2216cc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":710,"y":320,"wires":[]},{"id":"1782d03a.4e4ae","type":"inject","z":"7edb64d7.2216cc","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":320,"wires":[["6c3f0ba9.131de4"]]},{"id":"5ad1bd27.e1b3b4","type":"voltage_undivider","z":"7edb64d7.2216cc","name":"","Voltage_Input":"V-Volts","Resistor_1":"1.1","Resistor_1Types":"Ω-Ohm","Resistor_2":"2.1","Resistor_2Types":"Ω-Ohm","Voltage_Output":"V-Volts","Round_Output":"Thousandths","x":530,"y":320,"wires":[["c0a340e7.a8288"]]}]
Bugs / Feature request
Please report bugs and feel free to ask for new features directly on GitHub.
This project is licensed under Apache 2.0 license.
Work
_Need a node? _Need automation work? _Need computers to flip switches?
Contact me at [email protected]
Contributor of Project
Thanks to SunValleyFoods for being a buisness that supports opensource. They needed this node for a monitoring and automation project for their equipment.
release notes
0.0.0 = (majorchange) . (new_feature) . (bugfix-simple_mod)
version 0.8.9 Property option added to node bug fix for checks if null value
version 0.7.8 updated help txt updated images updated example code
version 0.7.7 fixed install command
version 0.7.6 First Public release
Version: 0.8.9
Updated 7 years, 3 months ago
7 in the last week
  • voltage_undivider
  • voltage
  • divider
  • converter
  • convert
  • volt
  • volts
  • undivider
  • un-divider
  • undivider
