node-red-contrib-vk-io-bot 0.0.4
npm install node-red-contrib-vk-io-bot
VK bot nodes for Node-RED
This package contains a receiver and a sender node which act as a Telegram Bot. The only thing required is the token that can be retrieved by the https://vk.com/club${id}?act=tokens.
You can install the nodes using node-red's "Manage palette" in the side bar.
Or run the following command in the root directory of your Node-RED installation
npm install node-red-contrib-vk-io-bot --save
Note that the minimum node-red version 1.3.7 and minimum nodejs version is 12.x.
Dependencies
The nodes are tested with Node.js v18.16.0 and Node-RED v3.0.2.
Basics
Config Receiver Sender Event Callback event Command Keyboard
Version: 0.0.4
Updated 3 years, 8 months ago
  • vk-config
  • recipient
  • sender
  • event
  • keyboard
  • command
  • callback-event
  • vk-io
  • bot
