node-red-contrib-vizio-remote 1.0.0
Node-RED nodes to pair with and control Vizio SmartCast TVs over the local network (power, volume, mute, inputs, playback, status).
Node-RED nodes to pair with and control Vizio SmartCast TVs over your local network, using the TV's built-in HTTPS API (port 7345). No cloud, no extra dependencies besides mDNS discovery.
Not affiliated with, endorsed by or sponsored by VIZIO, Inc. "VIZIO" and "SmartCast" are trademarks of their owners.
| Node | Purpose |
| vizio-tv (config) | Host, port and credentials for one TV. Has Discover and Pair buttons. |
| vizio-command | Power, volume, mute, playback, inputs, navigation, raw keys. |
| vizio-status | Reads power, current input, volume and mute state. |
Palette Manager → search node-red-contrib-vizio-remote, or:
cd ~/.node-red && npm install node-red-contrib-vizio-remote
Pairing a TV
- Add a vizio-command node and click the pencil next to TV to create a TV config.
- Click Discover TVs (or type the IP address by hand).
- Click Pair with TV. A PIN appears on the TV screen.
- Type the PIN and Submit. The auth token is filled in and stored as an encrypted Node-RED credential.
- Done, then Deploy.
Give the TV a fixed IP (DHCP reservation) for reliability. If the TV was discovered via mDNS and later changes address, the nodes search for it again and retry once, logging a warning.
vizio-command
Choose a fixed action in the editor, or (from msg.payload) to pick the action per message:
"PowerOn" // string = action (case/space/dash/underscore insensitive)
"volume_up"
{ "action": "volume_up", "amount": 5 } // five presses
{ "action": "volume_set", "volume": 25 } // absolute, 0–100
{ "action": "input_set", "input": "HDMI-2" } // also "SmartCast", or your own label e.g. "Game Console"
{ "action": "key", "codeset": 5, "code": 1 } // raw key
- Parameters (amount, volume, input) can be fixed values or read from
msg.*,flow.*,global.*or an env var. - Keys in an object
msg.payloadalways override the configured parameters. - A bare number as payload sets the amount (volume up/down) or the volume (set volume).
- A fixed action ignores string payloads, so a stray
"ON"from MQTT can't break it.
Actions: power_on power_off power_toggle · volume_up volume_down volume_set mute_on mute_off mute_toggle ·
play pause seek_forward seek_back · input_set input_next smartcast · channel_up channel_down channel_prev ·
up down left right ok back exit menu home info · closed_captions picture_mode picture_size · key.
Output: msg.payload = { ok: true, action, … }. Failures are raised as node errors (use a Catch node).
vizio-status
msg.payload = { power: true, input: "HDMI-3", inputLabel: "HTPC", volume: 30, muted: false }.
When the TV is off, only { power: false }.
Limitations
- No "stop" key: the SmartCast API only offers play and pause.
- Power on works only if the TV keeps its network connection while off (enable Quick Start / disable Eco mode in the TV's settings).
- Discovery uses multicast DNS. It does not cross Docker bridge networks or VLANs; use host networking or type the IP.
- Volume ×N sends N key presses ~100 ms apart because TVs can drop rapid repeats.
- The TV's HTTPS certificate is self-signed; certificate checking is disabled for connections to the TV only (never globally).
- Older firmware may use port 9000 instead of 7345.
- Developed and tested against a Vizio E-series (E55-E1) TV. Reports for other models are welcome.
Security note
The auth token grants full remote control of the TV on your LAN. It is stored in Node-RED's encrypted credentials file;
set a credentialSecret in settings.js and do not commit flows_cred.json. The pairing endpoints in the editor
require the Node-RED admin permission vizio-tv.write.
Development
npm install
npm test # runs against a local fake TV, no hardware needed
Key codes and endpoints were cross-checked against pyvizio.
MIT
