node-red-contrib-viseo-trello 0.4.0
VISEO Bot Maker - Trello
npm install node-red-contrib-viseo-trello
Node-RED
Trello list Card and Webhooks nodes.
This node is part of project node-red-contrib-viseo powered by VISEO Technologies. Please find the node documentation in the Node-RED info tab.
Here is a French Article on Bot Ecosystem and more.
Quick Start
Build the Node-RED Flow
The trello-in will trigger an event of each action on the target ModelId (board, card, user, ...).
Flow
On a Trello URL, add .json to get the board description and retrieve all modelIds.
Credential require a Trello Application Key and a Token.
The trello-card will retrieve, create, update or delete a board, a list, a card, a label or a custom field.
Flow 2
Configuration can be static or retrieved from the flow (payload.card.id). A Good practice is to retrieve a card from it's Id then chain it with an other node to perform an update.
Limitations
The trello-in node add routes to Node-RED server. Updating the node configuration will add new routes but won't remove previous. The Node-RES server must be restarted to clean up routes.
The trello-in node trigger add/update Trello webhooks. Previous webhooks are not removed. That's why we use an explicit callback path to limit errors. A webhook can be removed with a DELETE request to trello.
Getting Help
A documentation is available on this Wiki.
For further help, or general discussion, please use the github issue tracker and in order to be labeled with question tag please specify :
  • Your message is a question / discussion
  • The module or node name
Contributing
This project adheres to the Contributor Covenant 1.4. By participating, you are expected to uphold this code. Please report unacceptable behavior to any of the project's core team.
Authors
This project is a creation of VISEO Technology.
Copyright and license
Copyright 2016-2019 VISEO under the Apache 2.0 license. Copyright 2012-2019 SARAH under the Apache 2.0 license.
Version: 0.4.0
Updated 7 years, 3 months ago
52 in the last week
  • trello-config
  • trello-in
  • trello-card
  • viseo
  • sarah
  • trello
