node-red-contrib-view-email 1.12.5
Node-RED nodes to send and receive simple emails.
npm install node-red-contrib-view-email
node-red-node-email
Pre-requisite
You will need valid email credentials for your email server. For GMail this may mean getting an application password if you have two-factor authentication enabled.
Note : Version 1.x of this node requires Node.js v8 or newer.
You can install by using the Menu - Manage Palette option, or running the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-node-email
GMail users
If you are accessing GMail you may need to either enable an application password, or enable less secure access via your Google account settings.
Nodes to send and receive simple emails.
Input node
Fetches emails from an IMAP or POP3 server and forwards them onwards as messages if not already seen.
The subject is loaded into msg.topic and msg.payload is the plain text body. If there is text/html then that is returned in msg.html. msg.from and msg.date are also set if you need them.
Additionally msg.header contains the complete header object including to, cc and other potentially useful properties.
Output node
Sends the msg.payload as an email, with a subject of msg.topic.
The default message recipient can be configured in the node, if it is left blank it should be set using the msg.to property of the incoming message.
The email from can be set using msg.from but not all mail services allow this unless msg.from is also a valid userid or email address associated with the password. Note: if userid or msg.from does not contain a valid email address (userxx@some_domain.com), you may see (No Sender) in the email.
The payload can be html format. You can also specify msg.plaintext if the main payload is html.
If the payload is a binary buffer then it will be converted to an attachment.
The filename should be set using msg.filename. Optionally msg.description can be added for the body text.
Alternatively you may provide msg.attachments which should contain an array of one or more attachments in nodemailer format.
Uses the nodemailer npm module.
Version: 1.12.5
Updated 5 years, 9 months ago
Rating: 1.0 1
11 in the last week
  • e-mail
  • e-mail in
  • e-mail mta
  • email
  • gmail
  • imap
  • pop
  • mta
