node-red-contrib-victron-vedirect-usb 1.0.3
Access the Victron equipment with a USB VE.Direct cable
npm install node-red-contrib-victron-vedirect-usb
This node uses a VE.Direct USB connection to grab the communication on the serial port and translates it into usable data.
Example flow
A typical use case would be to run Node-RED on a Raspberry Pi and connect to the VE.Direct port of a Victron Energy device. E.g. a SmartShunt, BMV, Inverter or MPPT.
Once the node gets deployed it keeps on reading and stores the values as they get read from the serial port. It only outputs on 'inject', so it is needed to trigger output via an inject node to the node. Typically you would configure that to repeat on an interval of a few seconds.
Note that, when using this from a GX device, it requires you to disable serial-starter from using the VE.Direct usb cable. The way to accomplish this is described here.
Select the port to use from the dropdown. The dropdown is generated on the fly, so make sure that the USB part of the cable is connected to the system running Node-RED.
Note that there is a filter in place to first show cables that have the manufacturer set to Victron Energy BV. This is there, because if the node tries to connect to a non-functional port, it might crash Node-RED. This does not happen if it connects to a functional port.
But if you know what you are doing you can also select a non-tested device.
Timeout
Configure the stale data detection timeout in seconds (default: 10 seconds). If no data is received within this time, the node will stop outputting data and show a warning status. Leave the field empty to disable stale detection.
Output
The output depends on the connected product, but is based on the VE.Direct-Protocol-3.34.pdf.
The msg.payload holds the used VE.Direct label, the units, description and value. E.g.:
PID: {"value":"0xA389","description":"ProductID","units":"","product":"SmartShunt 500A/50mV"},
V: {"value":7814,"description":"Main or channel 1 (battery) voltage","units":"mV"},
I: {"value":0,"description":"Main or channel 1 battery current","units":"mA"}
The above example is abbreviated. It typically consists of more labels.
Status
The node shows a green dot with the connected product when functional. It will show a yellow dot with "stale data" when no data has been received within the configured timeout period. It will show a red dot with the error message when something went wrong.
Development
Project Structure
src/
├── lib/              # Pure functions and utilities (unit tested)
│   ├── checksum.js
│   ├── products.js
│   ├── field-definitions.js
│   ├── value-parser.js
│   └── stale-detector.js
├── services/         # Business logic and stream handlers
│   ├── parser.js
│   └── vedirect.js
└── nodes/           # Node-RED node implementations
    └── vedirect-usb.js
test/
├── unit/            # Unit tests
│   ├── lib/
│   ├── services/
│   └── utils/
└── fixtures/        # Test data and fixtures
Testing
This project uses Jest for unit testing.
# Run all tests
npm test
# Run tests in watch mode
npm run test:watch
# Run tests with coverage
npm run test:coverage
Coverage
Test coverage reports are generated in the coverage/ directory after running npm run test:coverage.
Target coverage goals:
  • lib/: 100% (pure functions should be fully testable)
  • services/: 80%+ (core business logic)
  • nodes/: Not covered by unit tests (requires Node-RED runtime)
License is GPL-3.0-or-later.
About
The code is based on https://github.com/bencevans/ve.direct of Ben Evans.
Refactored for better maintainability with:
  • Extracted pure functions for easy testing
  • Comprehensive unit test coverage with Jest
  • Modular architecture separating concerns
Version: 1.0.3
Updated 2 months, 1 week ago
License: GPL-3.0-or-later
Rating: 3.5 2
39 in the last week
  • victron-vedirect-usb
  • victron
  • vedirect
