node-red-contrib-vib-smart-valve 0.81.5
Smart Valve Managemeent
npm install node-red-contrib-vib-smart-valve
Smart-Valve Node
The smart-valve node is designed to manage heating valves (TRVs) in a Node-RED environment, specifically tailored for Home Assistant and MQTT integration. It allows grouping multiple valves in a single room, handling external temperature sensors, and managing manual overrides.
  • Multi-Valve Management: Group multiple TRVs to operate as a single zone.
  • External Temperature Reference: Use an external temperature sensor for more accurate room temperature readings.
  • MQTT Integration: Extensive use of MQTT for receiving status and sending commands.
  • Manual Override Detection: Detects if a valve's setpoint is changed manually and updates other valves in the group.
  • Boiler Integration: Sends demand signals to a smart-boiler node.
  • Auto-Calibration: (Optional) Adjusts valve temperature based on external sensor (if supported).
  • State Persistence: Automatically saves and restores setpoint and temperature values across Node-RED restarts and flow deploys.
General
  • Name: Node name, also used as the group name for the boiler.
  • Topic: MQTT topic (optional/informational).
  • MQTT Settings: Reference to a global MQTT configuration node.
  • Group ID: Unique integer ID for the valve group (required for smart-boiler).
Temperature Settings
  • Temperature Entity: Name of the external temperature sensor entity (e.g., sensor.living_room_temp).
  • Temperature Topic: MQTT topic for the external temperature sensor.
  • Off Setpoint: Temperature setpoint when the valve is turned "Off" (e.g., 5°C for frost protection).
Climates (Valves)
Define each valve controlled by this node:
  • Climate Entity: Home Assistant entity ID (e.g., climate.radiator_1).
  • Ext Temp Topic: MQTT topic to publish external temperature to the valve (for TRVs that support it).
  • Entity Topic: MQTT topic to receive status updates from the valve.
  • SetPoint Topic: MQTT topic to send setpoint commands to the valve.
Advanced
  • Update Mode:
    • when state changes: Send updates only when values change.
    • when state changes + startup: Send updates on change and node startup.
    • every cycle: Send updates every cycle regardless of changes.
  • Update Cycle: Duration in minutes between evaluation cycles (default: 5).
  • Allow Manual Update: If enabled, manual changes on a TRV will propagate to others and override the schedule.
  • Recalibration: Option to adjust valve temperature offset (requires specific TRV support).
  • Debug: Enable verbose logging to the Node-RED console.
Inputs
The node accepts messages to control its state:
  • Command: msg.payload.command
    • on / 1: Turn the node ON (Auto mode).
    • off / 0: Turn the node OFF (Frost protection mode).
    • set / trigger: Set a specific setpoint. Requires msg.payload.setpoint.
  • Setpoint: msg.payload.setpoint (Number) - Target temperature (required for set command).
Example msg.payload:
    "command": "set",
    "setpoint": 21.5
Business Rules
Valve Activation Condition
A valve is considered ACTIVE (heating required) when:
setpoint > temperature
This means heating is requested when the target temperature exceeds the current room temperature.
Target Conditions on Input
  • Command "set" or "on": Valve processes input if executionMode = true
  • Command "trigger" or "1": Only triggers evaluation if executionMode = true
  • Command "override": Always processed regardless of executionMode, forces setpoint update across all valves in group
  • Command "off" or "0": Sets executionMode = false, disables valve operation
  • GroupId matching: Input messages only processed if msg.payload.groupId matches the node's configured Group ID
  • Manual override propagation: When manual update is detected on one valve, all valves in the same group are synchronized to the new setpoint
Outputs
  1. Home Assistant / MQTT: (Deprecated/Internal) Used for direct service calls or debugging.
  2. Boiler / Scheduler: Sends status updates to smart-boiler or smart-scheduler.
    • msg.payload contains: command, topic, setpoint, temperature, name, groupid.
MQTT Topics
The node subscribes to:
  • Temperature Topic: To get the reference room temperature.
  • Entity Topic (for each climate): To get current TRV status (setpoint, local temp).
The node publishes to:
  • SetPoint Topic (for each climate): To set the target temperature.
  • Ext Temp Topic (for each climate): To push external temperature reference to TRVs.
Logic
  1. Initialization:
    • Connects to MQTT and subscribes to topics.
    • Loads last saved state from file system (.node-red-state/valve-{node-id}.json).
    • Restores previous setpoint and temperature values if available.
  2. Cycle (Every x minutes):
    • Phase 1 (Check): Checks if any valve was manually adjusted (if allowed).
    • Phase 2 (Update):
      • If manual update detected: Syncs all other valves to the new setpoint.
      • If no manual update: Enforces the requested setpoint (from input/schedule).
    • Phase 3 (Ext Temp): Updates TRVs with external temperature reading.
    • Phase 4 (Boiler): Sends current demand (setpoint vs current temp) to the boiler node.
    • Phase 5 (Persistence): Saves current state to file for persistence across restarts.
State Persistence
The node automatically saves its state to the file system at ~/.node-red/.node-red-state/valve-{node-id}.json. This includes:
  • requestSp: Requested setpoint
  • sp: Current setpoint
  • refTemp: Reference temperature from external sensor
  • timestamp: Last save timestamp
This state is automatically restored when:
  • Node-RED restarts
  • Flows are redeployed
  • Node is reinitialized
The state file persists independently of Node-RED's context storage, ensuring valve settings are preserved even after complete system restarts.
Author: Vincent BESSON License: Creative Commons
Buy Me A Coffee
Version: 0.81.5
Updated 11 months, 3 weeks ago
License: CC-BY-2.5
475 in the last week
  • smart-valve
  • smart-valve-settings
  • Heating
  • valve
  • trv
  • climate
