node-red-contrib-vib-smart-boiler 0.81.10
Smart boiler node to control multiple thermostat
npm install node-red-contrib-vib-smart-boiler
Smart-Boiler
Overview
Smart-Boiler is a core component of the intelligent heating control suite, designed to work in tandem with Smart-Scheduler and Smart-Valve.
  • Smart-Scheduler: Manages heating schedules and target temperatures.
  • Smart-Valve: Groups and controls individual radiator valves (TRVs) by room/zone.
  • Smart-Boiler: Acts as the central controller. It aggregates demand from all connected Smart-Valve nodes and determines the optimal boiler operation (On/Off, Setpoint) based on the highest heating requirement.
This node is designed to integrate with Home Assistant via MQTT and can optionally control an OpenTherm gateway.
  • Demand Aggregation: Collects temperature and setpoint data from multiple valves.
  • Intelligent Firing: Calculates the "Active Valve" based on the largest gap between setpoint and current temperature.
  • Safety Watchdog: Automatically reverts to safe defaults if no updates are received from valves within a configurable timeframe.
  • MQTT Integration: Publishes boiler status, setpoint, and the name of the "Leading Device" (the valve driving the boiler) to MQTT.
  • Message Storm Protection: Prevents processing overload by limiting the rate of incoming messages.
  • State Persistence: Automatically saves and restores the complete valve stack and boiler state across Node-RED restarts and flow deploys.
Input Message Format
The node expects a msg.payload object containing a command and valve data. This is typically generated automatically by Smart-Valve nodes.
Update Command (set)
Used to update the status of a valve in the boiler's internal stack.
msg.payload = {
    command: "set",         // Required
    setpoint: 21.5,         // Target temperature in °C (number)
    temperature: 19.0,      // Current temperature in °C (number)
    requestedBy: "Kitchen", // Unique name/ID of the valve (string)
    groupId: 1              // Group ID the valve belongs to (number)
Other Commands
  • command: "trigger": Forces the boiler to re-evaluate its state and publish updates immediately.
  • command: "stack": Outputs the current internal stack of known valves to the debug output.
Logic & Operation
1. Valve Stack Management
Every time a set command is received, the node updates its internal "Live Stack". If the valve (requestedBy) is new, it is added; otherwise, its values are updated.
2. Active Valve Selection
On every cycle (or update), the node evaluates all valves in the stack to determine if the boiler should run.
  • Active Condition: A valve is considered "Active" if setpoint > temperature.
  • Priority Rule: The boiler follows the valve with the highest gap (setpoint - temperature).
    • Example:
      • Valve A: SP 20°C, Temp 21°C (Inactive)
      • Valve B: SP 22°C, Temp 21°C (Gap +1)
      • Valve C: SP 24°C, Temp 20°C (Gap +4) -> Winner
    • Tie-Breaker: If gaps are equal, the valve with the higher setpoint wins.
3. Boiler Control
  • Heating On: If an Active Valve is found, the boiler is switched ON (via MQTT topic). The boiler setpoint is set to the Active Valve's setpoint.
  • Heating Off: If no valves are active (all rooms are warm enough), the boiler is switched OFF.
4. Safety Watchdog
If no valid input is received for a duration exceeding Max duration since last input (configurable):
  • The boiler enters Security Mode.
  • It publishes the Default Temp and Default Setpoint to the boiler.
  • This prevents the boiler from getting stuck in a "Heating" state if the control network fails.
Business Rules
Valve Activation Condition
A valve is considered ACTIVE when:
sp > temp
The boiler is controlled by the valve with the HIGHEST temperature gap:
gap = sp - temp
Target Conditions on Input
  • Valid input requires: msg.payload.command === "set" AND msg.topic matches the configured MQTT topic pattern
  • Message processing: Each input creates or updates a valve entry in the internal stack (liveStack)
  • Stack management: Valve entries are indexed by requestedBy (valve name/ID), ensuring unique valve identification
  • Cycle trigger: Every valid input triggers an evaluation cycle to determine the active valve
  • Timestamp tracking: Each valve entry records lastupdate for timeout monitoring
  • Security timeout: If no updates received within configured duration, system enters safe mode with default values
  • Command filtering: Only "set" commands are processed for valve updates; "trigger" forces immediate re-evaluation; "stack" outputs debug information
Parameter Description
Name Node name (also used as the Home Assistant device name).
Boiler Entity The ID of the boiler device in Home Assistant (used to auto-generate MQTT topics).
MQTT Settings Reference to the MQTT Broker configuration node.
MQTT Updates If checked, the node will publish updates to the configured MQTT topics.
Output Updates If checked, the node will send a message to its output port on change.
Update Cycle How often (in seconds) the node re-evaluates the valve stack.
Trigger Mode When to trigger outputs: State Change, State Change + Startup, or Every Cycle.
Max Duration Time (in minutes) without input before triggering Security Mode.
Default Temp/SP Fallback values used in Security Mode.
Boiler Security Enable/Disable the watchdog security feature.
Outputs
MQTT Topics
The node publishes to the following topics (prefixed by the configured root path, e.g., homeassistant/boiler_entity_id/...):
  • .../setpointTemperature/set: Target boiler water temperature (or room setpoint, depending on boiler mode).
  • .../currentTemperature/state: Current reference temperature (from the leading valve).
  • .../leadingDevice/state: Name of the valve currently controlling the boiler.
  • .../swCentralHeating/set: 1 (On) or 0 (Off).
Node Output
If Output Updates is enabled, the node sends:
msg.payload = {
    sp: 24,
    temp: 20,
    name: "Living Room", // Name of the active valve
    lastupdate: "2023-10-27T10:00:00.000Z",
    groupId: 1
State Persistence
The node automatically saves its complete state to the file system at ~/.node-red/.node-red-state/boiler-{node-id}.json. This includes:
  • liveStack: Complete array of all connected valves with their setpoints and temperatures
  • activeItem: Current active valve controlling the boiler
  • previousItem: Previous active valve
  • previousActiveItemSp: Previous setpoint for change detection
  • activeItemGap: Current temperature gap
  • lastInputTs: Timestamp of last received input
  • timestamp: Last save timestamp
This state is automatically restored when:
  • Node-RED restarts
  • Flows are redeployed
  • Node is reinitialized
The state file persists independently of Node-RED's context storage, ensuring the boiler remembers all connected valves and their states even after complete system restarts or redeployments. This prevents loss of heating control context and ensures seamless operation continuity.
  1. Install via Node-RED Palette Manager or npm install.
  2. Ensure you have an MQTT broker running.
  3. Configure the Smart-Valve nodes to send data to this Smart-Boiler node (usually via a Link node or direct wire).
Creative Commons
Version: 0.81.10
Updated 11 months, 2 weeks ago
License: CC-BY-2.5
764 in the last week
  • smart-boiler
  • smart-boiler-settings
  • Heating
  • valve
  • trv
  • climate
