node-red-contrib-velbus-2026 0.13.4
Node-RED palette for Velbus building automation — relay, dimmer, glass panel, PIR, blind, sensor, meteo, clock nodes. Original and V2 (-20) series.
npm install node-red-contrib-velbus-2026
A Node-RED palette for Velbus building automation systems.
⚠ Testing status: This palette was generated with Claude.ai and is in need of extensive field testing before being deployed into a commercial project. It is presented "as is" — any use beyond testing is entirely at your own risk and liability. Constructive feedback is welcomed, accompanied by as many examples and debug captures as possible. Please file an issue on GitHub.
About
Velbus is a CAN-bus building automation system manufactured in Belgium. This palette provides Node-RED nodes for all major Velbus module families — both the original series and the current V2 (-20 series) modules.
Developed and maintained by MDAR Limited, the UK distributor for Velbus building automation systems.
This is a ground-up rewrite replacing the abandoned node-red-contrib-velbus palette (last updated 2020).
Requirements
  • Node-RED v3.0 or later (tested on v5.0)
  • A Velbus TCP gateway:
  • Node.js 18+
  • Optional, for the module emulators (velbus-emulate-*) only: a persistent context store configured in settings.js if you want their memory (channel names, Linked Push Button entries) to survive a Node-RED restart — e.g. contextStorage: { default: { module: "localfilesystem" } }. Without it, the emulators still work fully, they just reset to factory-fresh memory on every restart.
Via palette manager: search for velbus-2026.
Via npm:
Via local tarball:
npm install /path/to/node-red-contrib-velbus-2026_vX.Y.Z.tar.gz
(replace X.Y.Z with whichever version tarball you have — deliberately not hardcoded here, since a literal version number in this file has gone stale every single time it's been written one before)
Infrastructure
Node Description
velbus-bridge Config node. TCP/TLS connection to gateway. Handles packet routing, subaddress mapping, scan locking.
velbus-scan Bus scanner. Sends RTR to all addresses 0xFE→0x01, collects 0xFF responses. Populates address dropdowns in all other nodes.
Inputs (teal)
Node Modules
velbus-glass-panel All VMBEL and VMBGP variants — 29 types including OLED, PIR, and original series. Thermostat, LED control, open collector. VMBEL family only: edge colour control (set_edge_color) — applies an already-defined colour across layer/edge/page combinations; defining new custom colours stays in VelbusLink.
velbus-thermostat Dedicated thermostat node for all glass panel modules.
velbus-button 12 types across original and V2 series: VMB8PB, VMB8PBU, VMB6PBN, VMB2PBN, VMB4PB, VMB6PB-20, VMB8IR, VMB4PD, VMB4RF, VMBRFR8S, VMBVP01, VMBKP, VMBIN. Lock/unlock and richer status decode where the specific type supports it (not universal); named channels in event output; fixed semantic labels for VMBVP01 (DoorBird).
velbus-pir VMBPIRM, VMBPIRC, VMBPIRO, VMBPIRO-10
velbus-pir-20 VMBPIR-20, VMBPIRO-20
velbus-meteo VMBMETEO — wind, rain, light, temperature, alarm outputs
velbus-sensor VMB7IN (8 digital inputs + 4 pulse counters), VMB4AN (channels 1-8 alarm outputs + generic analogue reading on channels 9-12 — mode-aware but deliberately no engineering-unit conversion), VMB6IN (6 digital inputs)
velbus-sensor-20 VMB8IN-20 (8 digital + 24 alarm channels via subaddresses, energy counters)
Outputs (blue)
Node Modules
velbus-relay VMB1RY, VMB4RY, VMB4RYLD, VMB4RYNO, VMB1RYNO, VMB1RYNOS, VMB1RYS, VMB4RYLD-10, VMB4RYNO-10
velbus-relay-20 VMB1RYS-20, VMB4RYLD-20, VMB4RYNO-20
velbus-dimmer VMBDMI, VMBDMI-R, VMB4DC
velbus-dimmer-20 VMB2DC-20, VMB8DC-20, VMB4LEDPWM-20
velbus-blind VMB1BL, VMB2BL — original series, stop/up/down only
velbus-blind-s VMB1BLS, VMB2BLE, VMB2BLE-10 — full position, lock, force, inhibit
velbus-blind-20 VMB2BLE-20 — V2 series with CAN FD support
velbus-clock No fixed module — broadcasts time/date/DST to bus address 0x00, plus global/local clock alarm and sunrise/sunset enable (V2 series only)
velbus-energy VMBPSUMNGR-20 — power supply manager: PSU load, live wattage/voltage/amperage, warranty counter, PSU alarms (V2 series only)
velbus-emulate-button-io Module emulator (new "Velbus (emulate)" category) — emulates a real VMB4PB in "I/O module" mode: 4 button inputs + 4 open-collector outputs, so VelbusLink can scan, see, and link against it without physical hardware
velbus-emulate-dimmer Module emulator — emulates a real VMB4DC, for the same training/testing purpose as above
velbus-emulate-counter Module emulator — emulates a real VMB7IN pulse-counting utility meter interface. Purpose-built for bringing third-party data (MQTT, Modbus, anything Node-RED can reach) onto the Velbus bus as a genuine module, so VelbusLink can assign it to a real OLED Counter page — not a scrolling text banner
Examples
After installation, example flows are available via Import → Examples → node-red-contrib-velbus-2026 in the Node-RED editor.
velbus-scan-and-relay
Bus scan, then on/off/toggle relay control — toggle demonstrates the node's own internal state tracking, not a wire command. Uses only core Node-RED nodes (inject, debug, comment) plus this package's own nodes, no other palette required.
To use: configure the velbus-bridge node, click "Scan bus" to find modules, open the relay node and select a real relay address from the scan results, then deploy and use the On/Off/Toggle inject buttons.
velbus-dimmer-levels
Preset-percentage dimmer control via inject buttons (0%, 25%, 50%, 100%).
To use: configure the velbus-bridge node, open the dimmer node and select a real V2-series dimmer address, then deploy.
velbus-scan-and-debug
A minimal bus scan with two debug outputs — the full raw scan result, and a status-line view showing just each discovered module as it's found.
To use: configure the velbus-bridge node, deploy, then click "Scan".
velbus-VMB4PB-emulator
Exercises velbus-emulate-button-io's full input contract: simulated button events (press/release/long, individually or combined) and direct output commands (on/off/toggle/force_off/force_toggle/force_cancel).
To use: configure the velbus-bridge node, confirm the emulator's address (0x60) is free on your bus, deploy, then try the inject buttons — watch the debug sidebar for the resulting output and forced-state changes.
velbus-counter-emulator-random-values
Generates plausible-looking live data for velbus-emulate-counter's 4 reference channels (electricity/kWh, water/liter, gas/m³, a second liter channel) every 3 seconds — useful for watching real OLED Counter page behaviour update live without a real utility meter connected.
To use: configure the velbus-bridge node, confirm the emulator's address (0x50) and channel configuration match your own setup, then deploy — the inject node fires automatically every 3 seconds. Cumulative values genuinely accumulate over time (reset on redeploy); the current rate is randomised within a plausible range each cycle rather than derived from the cumulative change, so treat it as "moving numbers for a real display," not a physically accurate simulation.
Quick start
  1. Add a velbus-bridge config node pointing at your gateway (default: 127.0.0.1:6000)
  2. Add a velbus-scan node, connect to the bridge, deploy and inject to scan
  3. All other nodes will have address dropdowns populated from the scan results
  4. Add the node for your module type, select the address, deploy
Confirmed hardware
Tested on a live 18-module installation including VMBEL4, VMBELO, VMBELPIR, VMBPIR-20, VMB1RYS, and VMB8DC-20. CAN FD modules confirmed working. VMBGPOD specifically confirmed against two real panels on a separate installation, after an earlier gap where it showed as unknown in a scan.
Further documentation
  • HANDOVER.md — comprehensive technical reference for developing this palette: architecture, protocol quirks found the hard way, per-node testing status, and known open issues. Written to assume no prior context.
  • CHANGELOG_FORUM.md — full version-by-version development history, including why things changed, not just what.
  • coverage-roadmap.md — every Velbus module type and feature considered for this palette, what's in scope, and why.
Contributing
Issues and pull requests welcome at the GitHub repository.
Please include Node-RED version, gateway type, module model and firmware build, and a packet capture where possible.
Licence
MIT — see LICENSE
Author
Stuart Hanlon, MDAR Limited
Version: 0.13.4
Updated 4 months, 2 weeks ago
757 in the last week
  • velbus-bridge
  • velbus-scan
  • velbus-relay
  • velbus-relay-20
  • velbus-dimmer
  • velbus-dimmer-20
  • velbus-glass-panel
  • velbus-thermostat
  • velbus-button
  • velbus-pir
  • velbus-pir-20
  • velbus-meteo
  • velbus-sensor
  • velbus-sensor-20
  • velbus-blind
  • velbus-blind-s
  • velbus-blind-20
  • velbus-clock
  • velbus-energy
  • velbus-emulate-button-io
  • velbus-emulate-dimmer
  • velbus-emulate-counter
  • velbus
  • building-automation
  • home-automation
  • smart-home
  • relay
  • dimmer
