node-red-contrib-veida 1.0.0
Node-RED node for Veida AI: turn a prompt into an AI image, or edit an image, and get back a CDN link. Works on the free tier with no API key.
npm install node-red-contrib-veida
Veida AI is an unlimited free AI image generator. This Node-RED node brings it into your flows: send a prompt, get back a link to the finished image, or pass an image URL and an instruction to edit it.
No API key is needed to start. Without one the node runs on Veida AI's free tier: each message is one run on Veida AI Image v1, about seven a day per machine, 1K with a small mark. Add a key from veida.ai/settings/apikeys to run on your account.
From the palette manager search for node-red-contrib-veida, or:
Use
Input What it does
msg.payload (string) The prompt
msg.image (URL, optional) Edit this image instead of generating a new one
msg.aspectRatio (optional) 1:1, 16:9, 9:16, 4:3 or 3:4
Output: msg.payload is the image URL, msg.veida is { url, watermarked }.
Import examples/generate-image.json for a ready-made inject → veida image → debug flow.
The same engine in a browser
Want to try prompts before wiring them into a flow? The ChatGPT image generator on Veida AI runs the same requests in a page, free with no sign-up.
MIT
Version: 1.0.0
Updated 3 weeks, 1 day ago
  • veida-image
  • veida
  • ai
  • image-generation
  • text-to-image
  • image-editing
