node-red-contrib-v430-barcode 0.2.7
Node-RED node for streaming barcode data from an Omron V430 websocket endpoint.
npm install node-red-contrib-v430-barcode
V430 WebSocket Barcode Node
Node-RED node for streaming barcode reads from an Omron V430 over WebSocket.
Install from the Node-RED Palette Manager by searching for node-red-contrib-v430-barcode, or run:
Restart Node-RED and add V430 sBarcode from the omron category.
Behavior
  • Connects to the fixed V430 endpoint
  • Decodes text WebSocket frames and binary MessagePack frames.
  • Sends the decoded barcode on output 1 and the complete event metadata on output 2.
  • Starts the WebSocket client only when Enabled is selected.
Field Description
Name Optional display name for the node.
Host / IP Hostname or IP address of the V430.
Enabled Opens the WebSocket connection when selected.
Timeout ms WebSocket handshake timeout.
Reconnect ms Delay before reconnecting after a closed connection.
Outputs
Output 1 sends the barcode read:
  "topic": "v430/barcode",
  "payload": {
    "barcode": "0041199006794",
    "symbology": "EAN13",
    "host": "192.168.250.2",
    "port": 50502,
    "path": "/",
    "cycle_id": "0x000000e6",
    "read_time_ms": 86,
    "cycle_time_ms": 485,
    "received_at": "2026-07-06T14:30:00.000Z"
Output 2 sends the complete event metadata under msg.payload. Output 1 also includes the decoded frame at msg.raw_event.
Local Development
  1. Run npm install in this folder.
  2. Run npm test.
  3. In your Node-RED user directory, run npm install <path-to-this-folder>.
  4. Restart Node-RED.
Publishing
This package includes the Node-RED manifest, public publish configuration, README, license, and runtime/editor files required for palette discovery. Authenticate to npm with an account that maintains node-red-contrib-v430-barcode, then run:
npm publish
Node-RED automatically indexes public npm packages whose names begin with node-red-contrib- and contain a node-red manifest. Palette availability can take several minutes after publishing.
Version: 0.2.7
Updated 3 months ago
2 in the last week
  • omron
  • v430
  • barcode
  • websocket
  • msgpack
