node-red-contrib-utm 1.0.0
A Node-RED node to convert co-ordinates to and from utm
npm install node-red-contrib-utm
A Node-RED node to convert co-ordinates in Latitude and Longitude to and from UTM format.
Either use the Node-RED menu - manage palette - install option, or run the following command in your Node-RED user directory - typically ~/.node-red
npm i node-red-contrib-utm
If msg.payload contains .lat and .lon properties, this node adds a corresponding UTM location as msg.payload.utm.
If the object contains a msg.payload.utm property as below, and not .lat and .lon, then .lat and .lon will be created.
msg.payload.utm.x = eastings
msg.payload.utm.y = northings
msg.payload.utm.z = zone code - eg 30U
Version: 1.0.0
Updated 2 years ago
13 in the last week
  • utm
  • map
  • world
  • utm
